01-27-2018, 07:26 PM | #1 |
6 tab flexplate?
So I just got my 12" ACC th400 6 tab torque converter, I also received my flexplate from rock auto. The flexplate only mates up with 3 tabs, can I enlarge the other three holes on the flexplate to fit TC?
Thanks |
01-27-2018, 07:59 PM | #2 |
Who Changed This?
Re: 6 tab flexplate?
Does it really need to have all 6 holes bolted up? There shouldn't be any issues opening the other holes up, but I'd recommend making sure that they are smooth so cracks don't have a place to initiate from.
01-27-2018, 08:54 PM | #3 |
I'd like to have all 6 if possible. Anyone have the part number for a flexplate with 6 correct holes for a 350 engine to th400?
01-27-2018, 08:58 PM | #4 |
Are you sure it's not a dual bolt pattern? Early flexplates were SAE pattern and later ones are metric.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-27-2018, 11:08 PM | #5 |
01-27-2018, 11:19 PM | #6 |
Who Changed This?
How much torque does your engine put out? A 454 truck still only uses 3 bolts from the converter to the flex plate. I think you are chasing your tail with using 6 bolts.
01-27-2018, 11:51 PM | #7 | |
I would be concerned about damaging the flexplate if you redrill or enlarge the other holes.
01-27-2018, 11:54 PM | #8 |
250hp 350ftlb, it's really low. So it should be ok leaving three tabs with no bolts? Still need to find some 3/8-16 Bolta for it too.
01-28-2018, 01:57 AM | #9 |
Three bolts. That's all it needs.
01-28-2018, 06:48 AM | #10 |
Sweet, thanks!
01-28-2018, 06:48 AM | #11 |
BTW, do you use lock washers or lock Tite?
01-28-2018, 08:46 AM | #12 |
Either works.
BTW, one tone trucks with 350/th400 combinations used 6 bolts on the torque converter.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
01-28-2018, 11:09 AM | #13 |
Good to know the 1 ton thing. Mines 1/2 ton.
01-28-2018, 01:54 PM | #14 |
Some later trucks used six bolts. I found a Pioneer FRA-145 flex plate on ebay which had six 11.5 holes for a 454. It was an old leftover and they don't list it any more. Now they list a FRA-141 for the 454 which is a dual pattern with 3 @ 11.5 and 3 @ 10 3/4" and the hole are very large in it.
1968 SWB Step Side, Big Block, 4L80E , Running! |
01-28-2018, 04:23 PM | #15 | |
01-28-2018, 06:15 PM | #16 |
I wouldn't do that. The 454 is balanced externally and SBCs are balanced internally (except the 400). The 454 flexplate has a balance weight on it, and you're going to have a heck of a vibration you just can't get rid of.
Just use the three bolts. It's how it was designed to run.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson Last edited by truckster; 01-28-2018 at 09:18 PM. |
01-28-2018, 08:43 PM | #17 | |
