Old 01-28-2018, 01:10 AM   #1
Buda63
Buda63's Avatar
Radiator Recommendation
My radiator finally took a dump on me and I need a replacement. I have a 62 with a 350 engine and 700r4 tranny. I would also like to convert to an electric fan with a new radiator. Any recommendations?
Buda63 is offline   Reply With Quote
Old 01-28-2018, 10:18 AM   #2
Macdaddy1
Re: Radiator Recommendation
Auto City Classics has them with the electric fan and I think has the best price. Good luck.
Macdaddy1 is offline   Reply With Quote
Old 01-28-2018, 11:46 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Champion has worked well for me.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-28-2018, 12:27 PM   #4
Wrenchbender Ret
The Champion aluminum radiators are hard to beat for cooling & price.
George
Wrenchbender Ret is offline   Reply With Quote
Old 01-28-2018, 12:38 PM   #5
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.speedcooling.com/1963_196..._Radiator.html . If I have to get another one I would go with this. it is a 2 row but 1" tubes. Not a bad price either. Little expensive with dual fans. http://www.speedcooling.com/1963-196...um-Shroud.html
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-28-2018, 05:35 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
My radiator started leaking last year, and I took it to get re-cored, but the shop I took it to said it was going to be 400 bucks to do that so instead, I bought a Champion and haven't had any issues since. Only thing with the Champion is that I had to slightly trim the rubber pads in order to make it sit good and solid.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-28-2018, 06:13 PM   #7
LVPhotos
LVPhotos's Avatar
I run my stock 62 radiator with a Flex-a-lite Black Magic 3300cfm flx-180. If you can save the original. Its a V cell not a cross flow radiator. My radiator shop guy gave me the "foot to ass" if I tossed it. Cools a 406 in 120* temps
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-28-2018, 08:31 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
If I were not going to use the stock shroud I would look into something like this:
http://www.mahaffeymotorsports.com/FanShrouds.htm
These guys also make shrouds - http://www.cadtechindustries.com/products.htm
Old 01-28-2018, 10:24 PM   #9
Buda63
Buda63's Avatar
Thanks to everyone for the recommendations. I will be researching prices tonight and let you know what I decide.
