01-28-2018, 11:49 AM | #1 |
Fuel Tank Selector Valve Wiring
For those wanting to use an regular on/off switch to switch fuel tanks, I researched wiring and found nothing so I created my own. I attached my wiring diagram and my push/pull switch. I hope this helps somebody as it was rather painful to put it all together.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
01-28-2018, 01:23 PM | #2 |
Re: Fuel Tank Selector Valve Wiring
Nice job Don. I'm assuming you're running two saddle tanks and no interior tank, is that right? And the push/pull switch is the one just below the choke pull? Looks like a nice clean job and thanks for sharing. If you eliminated the cab tank, then the wiring should be similar to a factory NL2 aux tank wiring arrangement. Wish I'd known you couldn't find the wiring diagrams you were looking for - I know it's too late, but here's some I have had saved away - some are for saddle tank arrangements, some for NL2, they may or may not have been any help to you - and may or may not be of any help to anyone else, but this is potentially a great ref thread, so will add to the pile of refs. Thanks again for posting, very helpful and I like your stealth switch arrangement. Any details on how you did that? it looks great.
1st 2 pics are for dual saddles and the last 2 pics are factory NL2. |
01-28-2018, 01:53 PM | #3 |
Jocko, that just switches the gauge to L/R tank sensor. That's used with manually switched tank fuel lines.
The switch for the later tank Selector valve is much simpler and requires no relays and is actually more user friendly. Flipping the toggle up or down, allows you to check fuel level in the other tank without actually changing tank feed. Pressing on the toggle , in either the up/down position then changes the tank. I'm not sure what your switch is doing, but it may be energizing the selector solenoid at all times and it shouldn't. It only needs power when switching. And, the correct switch is only $14 at O'Reilly, BWD Part # S743.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 01-28-2018 at 02:00 PM. |
01-28-2018, 02:05 PM | #4 | |
I'm running the in cab tank and a Blazer tank in the back. I got the push pull switch from the parts house and replaced the button with a choke knob. The 2 power wires run to behind the seat and I used a 4 pin trailer connector to run them under the truck through the floor as well as the wire for the in cab fuel tank gauge. I am also running a single mechanical fuel pump.
01-28-2018, 02:10 PM | #5 | |
01-28-2018, 02:23 PM | #6 | |
01-28-2018, 02:50 PM | #7 | |
EDIT: Thanks for pointing this out Richard - I kinda missed the mark on my post, it's not exactly pertinent to the thread and what the OP has accomplished or what you're talking about. Just to be crystal clear for folks that read this down the road, post #2 is for wiring a selector switch (either the factory switch for RPO NL2 or aftermarket saddles) to choose which tank is displayed on the fuel gauge only, totally independent of manually switching the fuel source tank (on the floor board). Sorry for injecting confusion. I kinda prefer the manual setup as it allows me to check tank qtys without switching. But power switching the fuel source would be kinda neat too Last edited by jocko; 01-28-2018 at 03:32 PM. |
01-28-2018, 03:17 PM | #8 |
>>but the switches for the later years were not momentary either <<
What later years? Parts reference lists this switch as used up to 1991. Leaving that solenoid constantly powered and heating up is a bad idea. Your switch, relays and extra jumble of wire didn't belong on the 67-72 truck either.
'67 GMC 2500, 292, 4spd, AC |
01-28-2018, 04:45 PM | #9 |
If all it did was switch the sending units, I'd think it was an awful lot of work for something I could have done with a toggle switch under the dash. I also don't think I would have made a pretty picture of my wiring schematic either.
01-28-2018, 08:41 PM | #10 |
I'm sorry, I had no intention of offending anyone with my work to my truck. My intent was to show work I did to it that works. I had no idea it was going to be chewed up with base assumptions from folks who didn't bother to read my post to begin with.
The stock non-momentary switch was found on models with TBI. This was necessary as the fuel pumps got their power off the valve's power supply and fuel pumps need to run something along the lines of not momentary. For the record, I do not require anyone's permission to add, change or delete a damn thing on my truck.
01-28-2018, 08:46 PM | #11 | |
Stan 67 swb BLU MULE posted via flip-fone |
