Fuel Pump (BBC) for a Quadrajet
Looking for advice on a mechanical fuel pump with a PSI low enough for the quadrajet. Previously had a AC DELCO 40727, 7.5-9psi was far too high for the QJet. Input?
*Relevant info Truck: 1969 K10 (Manual) Engine: 1977 (Mark IV) 454 Carburetor: 1973 R4-4MV Rochester Quadrajet Last edited by ekneen; 01-28-2018 at 09:40 PM. Reason: specifying mechanical |
Re: Fuel Pump (BBC) for a Quadrajet
I have had two C20s with 454 and qjets and replaced the fuel pumps with auto parts store brands. I did not know that there was a particular problem with the fuel pump pressure.
Sometimes there is.
I’ve had one that put out 9 psi. |
I have never had a parts store pump put out more than 5 psi. I hope I can find one of these high pressure pumps when I build my Camaro.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Why not install an adjustable pressure regulator? You can tune it to what your engine needs.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
