Old 01-28-2018, 07:12 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
Replacing Upper Control Arm Studs
Is it as simple as beating them out? or do you need to remove the frame/crossmember brace the studs go though?
truck is a 70 gmc C25.
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
