Old 01-28-2018, 09:29 PM   #1
raidmagic
raidmagic's Avatar
Where does the water go?
Ok so I removed my vents, the ones down by your feet. Welded up the backs and made speaker boxes out of them. So when it rains, where does the water go? I have a small amount of water leaking in the cab just under the vent. I guess I need to take it back out. I didn't really pay attention when it was out is there suppose to be a drain in that part of the body? Thanks.
raidmagic is offline   Reply With Quote
Old 01-29-2018, 12:33 AM   #2
Captainfab
60-66 Nut
Re: Where does the water go?
Yes there is a drain port at the bottom of the airbox on the outside of the cab. It is covered by the fender. Your water leak could also be up above around the windshield or at the seam for the cowl channel where it meets the piece of the outside airbox.
