Old 01-28-2018, 11:17 PM   #1
Jason7121
Jason7121's Avatar
Transmission cooler lines ls swap
I did an Ls swap in my c10 and want to run the 03 trans lines to the radiatior. The lines use the quick connect push in fittings. Is there an adapter fitting to accept the quick connect fitting and screw into the radiatior which is 1/2"-20 inverted flare? Thanks for any help I have been searching for the correct thing but no luck so far.
Jason7121 is offline   Reply With Quote
Old 01-28-2018, 11:23 PM   #2
72blu
72blu's Avatar
Re: Transmission cooler lines ls swap
is it possible to just cut the quick connect ends off and just flare the line like factory? I ask this because that's what I did to connect the LS power steering lines to the factory steering box.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges
1972 SWB Custom 10, gauges, cammed LQ9, M22
72blu is offline   Reply With Quote
Old 01-29-2018, 12:01 AM   #3
Jason7121
Jason7121's Avatar
I think I would like to run the push in style fittings with some sort of adapters to make it work
Old 01-29-2018, 12:37 AM   #4
Curtb1971
Curtb1971's Avatar
Search dorman 800-605 I looked into these in my swap for the quick connect at the radiator but ended up doing an 45 inverted flare to an adapter fitting. I did use the quick connect on the transmission because I bought the flaring die anyway and had to try it out.
1971 LSX "Bonnie" build thread
http://67-72chevytrucks.com/vboard/s....php?p=8026381
paypal is curtbarton1971@yahoo.com
Curtb1971 is offline   Reply With Quote
Old 01-29-2018, 01:24 AM   #5
Jason7121
Jason7121's Avatar
Will look into that thank you for the information
Old 01-29-2018, 01:29 AM   #6
Jason7121
Jason7121's Avatar
Those look right but need adapters to screw them into radiator
Old 01-29-2018, 08:19 PM   #7
72MARIO
72MARIO's Avatar
Russell makes adapters for the 4l60 and 4l80 that go to -6 definetally the best way to run transmission lines. I tried using factory type but the hassle was not worth it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-29-2018, 08:21 PM   #8
72MARIO
72MARIO's Avatar
http://www.russellperformance.com/mc/driveline/
Be careful if you have a 4l80. They fittings are specific to lube rear center support
2005 TAHOE DD
Old 01-29-2018, 08:32 PM   #9
Jason7121
Jason7121's Avatar
Yeah 4l60e trans is what I have
