01-29-2018, 12:13 AM | #1 |
What is this part called?
on the passenger side inside the cab of my 68 is a round hole on the upper body, like a coat rack clip. what is this part called and where can I find one? thanks, Larry
01-29-2018, 12:34 AM | #2 |
Re: What is this part called?
The hole was for shoulder seat belts, really rare option for these trucks. You can use the hole to instal new three point seat belts as well. These have a plastic plug over them. I have seen a few trucks with coat hooks mounted above the seat belt hole, and you can find them here, hope this helps!
https://www.classicindustries.com/pr...IaAlb8EALw_wcB
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
01-29-2018, 12:35 AM | #3 | |
The Older Generation
Is there actually something there or just the hole? LockDoc
01-29-2018, 01:21 AM | #4 |
just the hole, looking for a plug
01-29-2018, 08:48 AM | #5 |
If you can't find a plug but want to fill those two holes, here's what I did. Napa has these LED marker lights. They press in pretty good. I wired them into the stock dome light wire. They are bright.
01-29-2018, 10:08 AM | #6 |
Sounds like somebody knocked that out.
01-29-2018, 10:53 AM | #7 |
Try your local Ace Hardware if you have one. They should have them.
LockDoc
01-29-2018, 03:01 PM | #8 |
My 67 C10 had a captured nut behind the plastic plug. I install 3-point seat belts from a mid 80's Blazer. Captured nuts are also under the seat on both sides of the hump. According to the FMVSS, seat belts for trucks where not required until July of 1971. They where an option prior to that. I also found an RPO code for "Large Rear Window" in 1967 as it became standard in 68.
01-29-2018, 11:56 PM | #9 |
Seat belts weren't mandated till '71 but were standard equipment through these years.
01-31-2018, 02:08 PM | #10 |
as luck would have it, I was in LA for the roadster show, so I drove to Classic Industries. the part # is J1074, seat belt plug at $2.99 for 2. thanks for the help guys, Larry
