Old 01-29-2018, 10:36 AM   #1
jrblanke
1987 R10 w/ Factory TBI Stumbles and Dies when Hot
1987 R10 w/ factory TBI stumbles when hot.
Question regarding a friend’s 1987 R10 long bed. The truck cold starts fine, but when it gets hot it is difficult to start. Once its hot it takes longer to fire, and when it does fire, it will die when he shifts it into drive.
Is this a common problem? Is there anything in particular to look for when doing a tune up? As said on the title, the truck has factory fuel injection and is completely stock.
jrblanke is offline   Reply With Quote
Old 01-29-2018, 02:06 PM   #2
xs-style
xs-style's Avatar
Re: 1987 R10 w/ Factory TBI Stumbles and Dies when Hot
Replace the fuel filter. If your doing a tune up anyway, 6 bucks is a small price to pay for an item that's often forgotten or plain old skipped over. Also go to your local harbor freight and get a fuel pressure tester , a vacuum tester, and a multimeter. They run about 15 bucks each. Fuel delivery problems or vacuum issues are normally the cause of what your describing.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 01-29-2018, 02:18 PM   #3
Tiger Joe
x2 start with fuel filter. I had similar issues with my 87 tbi- stumbling at idle and die when shifting into park, and a new fuel filter fixed it
Tiger Joe is offline   Reply With Quote
Old 01-30-2018, 10:53 AM   #4
Desert1957
Desert1957's Avatar
x3
Desert
Desert1957 is offline   Reply With Quote
Old 01-30-2018, 03:40 PM   #5
jrblanke
The fuel filter was recently replaced. It starts right up idles fine when cold but stumbles and is difficult to start when hot. Once it’s started it has plenty of power throughout the rpm range.
Old 01-30-2018, 03:45 PM   #6
xs-style
xs-style's Avatar
Pull the starter and have it tested. They can heat soak if not properly shielded, especially with age. Your local AutoZone can do it. Have them run the test a few times so it gets warm. On the same trip you could take the ignition control module. It can be tested as well. Same deal, ask them to run the test a few times so it gets warm.
Events attended:
Spring GOG 2011
Old 01-30-2018, 04:45 PM   #7
jrblanke
I am not familiar with the term heat soak, but the truck isn't having a hard time turning over. It seems like either a spark or fuel issue. I assume that it is a fuel issue since the truck runs fine. Is there a fuel check valve or something that is malfunctioning when the engine is hot?
Old 01-30-2018, 07:33 PM   #8
xs-style
xs-style's Avatar
There's no fuel check valve or anything. But like I say, have that ignition control module tested. A wells tester puts it under normal operating load. If it gets hot and fails the wells test, you'll know that component is bad.
Events attended:
Spring GOG 2011
Old 01-31-2018, 10:08 AM   #9
cadillac_al
I'd say if there are no codes it must be a fuel pump going bad or the fuel filter.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-01-2018, 10:26 AM   #10
v30crewcab
v30crewcab's Avatar
sounds like the coil is messing up when it gets warm. other possibility is the distributor is worn. we had one that would randomly shut off when running. distributor fixed it.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 02-01-2018, 02:29 PM   #11
D13
D13's Avatar
Classic symptom of coil or weak ignition module. Check for good hot spark while cranking.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-02-2018, 08:12 AM   #12
jrblanke
Thanks guys, Sounds like we have some things to check. I appreciate the help! I'll report back once we get a chance to work on it some more.
Old 02-05-2018, 06:50 PM   #13
blakerj10
My blazer was doing something similar. Died on me about 5 or 6 times in about 6 months. Would restart after cooling off a bit. Then it died and would not restart. Took ignition module out of distributor (youtube video out there). Autozone can test them. Popped new one in and runs better than anytime since I have had it.
blakerj10 is offline   Reply With Quote
