Old 01-29-2018, 01:56 PM   #1
superhondaz50
superhondaz50's Avatar
Really stupid question.
So I'm putting I'm my fuel lines. 3/8 stainless from the engine bay all the way to the back to a K5 tank, 1/4 stainless return as well. Now my question, do I use small sections of regular rubber line and clamps to connect the fuel line to the fuel pump, and to the sending unit, or is there something special to connect them? This truck hasn't had line in years and have no clue how it is supposed to be set-up haha
superhondaz50 is offline   Reply With Quote
Old 01-29-2018, 02:33 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Really stupid question.
factory used small lengths of rubber fuel line hose....it's suction...not pressure...don't use rubber from the fuel pump to the carb...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-29-2018, 02:54 PM   #3
geezer#99
geezer#99's Avatar
You need to put a single flare on the tubing wherever you hook a piece of hose on.
Old 01-29-2018, 03:00 PM   #4
superhondaz50
Nice, ok. I have a hard line I made to go to the carb.
Old 01-29-2018, 03:01 PM   #5
superhondaz50
Can do.
Old 01-29-2018, 04:56 PM   #6
superhondaz50
One last question for anyone that has or has seen blazer/suburban fuel lines, do the hard lines end in the frame rail by the tank and have rubber going from the frame rail to the tank, or do they bend and go all the way to the sending unit?
Old 01-29-2018, 07:08 PM   #7
kwmech
No need to put a complete single flare on the end as it can cut the hose from the inside. All that is needed is to create the bubble on the end where the clamp will hold the hose to keep it from coming off under pressure
