Old 01-29-2018, 09:04 PM   #1
Drummerboy
Drummerboy's Avatar
So how much rust is too much rust???
So what would you consider too much rust on a truck like ours? Inner rockers, outers, kick panels....?
Drummerboy is offline   Reply With Quote
Old 01-29-2018, 09:13 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: So how much rust is too much rust???
They all have rust in those areas you listed at this point! The lower half stuff is easy. It's the areas up in the firewall, windshield cowl, inner roof structure, etc that worry me. Probably has more to do with parts availability and aftermarket support than anything else. Or maybe I'm just a wuss? My truck's cab looked 'good' with paint on it before I tore it apart - I ended up doing inner & outer rockers, kick panels, cab corners, and door bottoms on both sides, along with some floor patches on the driver's side. No big deal, if you like cutting, cussing and welding in marginally fitting aftermarket parts in preparation for a really nice paint job!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 01-29-2018, 10:38 PM   #3
Drummerboy
Drummerboy's Avatar
All good points BossHogg. I see that we're neighbors...
Old 01-29-2018, 10:48 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Need to also consider what the truck is. I would have more rust fixed on a rarer truck than a low dollar truck.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-29-2018, 10:50 PM   #5
saxart
saxart's Avatar
When the windshield pops out as you go around a corner. THAT's too much rust!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 01-29-2018, 11:03 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I've got two Chevys and they're miles apart.
My project truck, which I've had approaching 30 now is near rust free.........Core got hit a bit due to battery acid. LH inner fender was hit where it fastens to the fender, about 1" of surface rust on the window frame, and some surface rust on the LH cab floor. Course the other 2-3 items like the pumpkin cover, that if not pitted, it's spent life as a garage queen in the dry. Nice truck for a first project novice, like myself. I didn't cut, drill or torch a single fastener.
Then there's my driver, which I believe the original owner lived near the coast. Every common area on the cab was hit but the rockers, somehow. Maybe they were replaced. Rust burned through all four corners of the floor, the firewall, window, gutter and even the ceiling. No doubt the cowl too, I didn't even care to check. The fenders are hit in spots, as are the doors. Bed floor too, but not bad. The tailgate is toast...........While some would be happy to restore the truck it won't be me. Shame too, it was dynamite off the line. To me it's just a runner and I enjoy the drive.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
