01-31-2018, 12:52 AM | #1 |
Calibration
Need tips on how I calibrate my sending unit after put a new gas tank under bed. The fuel sender was stopped between zero and half.
01-31-2018, 09:47 AM | #2 |
Re: Calibration
The ohm range for the factory sender is 0-90. You will have to adjust your sender to get the ohm range within the correct swing of the arm to match your fuel tank.
If that sender has a different ohm range than 0-90, you may be out of luck, or will have to make some kind of resistor bridge to get it right.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-31-2018, 11:37 AM | #3 |
Re: Calibration
What Clay said. I go a step further. I measure the tank depth, make a simple diagram on paper & check the sweep with the sender out of the tank. I check it wired up to confirm the gauge is reading correctly. I also set the sender to read empty before the tank is empty.
