12 bolt backing plate
Can you guys help me? I have been searching for a few days now trying to get a parts vendor for a new passenger side rear backing plate for a 12 bolt gm truck rear axle. I can't seem to be able to purchase one anywhere. Any help?
Re: 12 bolt backing plate
Drum brakes I assume?
should be the same as 10 bolt other than shoe size and width . also parking brake cable style .
i know guys swap them a lot from 1 axle to other . my 2wd i did . the 12 bolt rear has the wide brake backing plate's on it for 1/2 ton . whats wrong with yours ?
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
it rusted through. I just need a new replacement one. The axle is out of i think a 1980 K10 but its going to a custom build (51 chevy 3100)
anyone???
You could try here.
They might have one or know a source. https://www.currieenterprises.com/Ba...0Brake%20Parts Or here. https://www.dormanproducts.com/gsear...or+drum+brakes |
I already contacted dorman, No luck on my search and no response from them. The curries, are ford loaded brake assemblies
Oops!!
Have you tried your local parts emporiums? |
I am my own local parts emporium.. hahaha
If they just rusted wore out on the wear points. (slide area) sand blast them weld them back up. Old Truck fix backers. I bleave that no one makes them yet.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#12 | |
no they rusted out and got holes in them, need replacment ones. Which BTW big shoutout to @1957Chief for sending me a pair of backing plates. The are a good fit. They will get a quick sanding, primer, and paint before installing. THANKS! |
| Bookmarks |
