Old 01-31-2018, 11:51 AM   #1
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Where to get outer bottom seat springs?
I am replacing the cover on my 71 bench seat and the outer springs that support the edge are broken on the seat bottom. Can anyone suggest a site to buy replacements ? Thanks
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 01-31-2018, 12:09 PM   #2
Missourimark
Missourimark's Avatar
Re: Where to get outer bottom seat springs?
I got mine from a old grain truck that a friend was salvaging out. Used the passenger side, the drivers side was broke too. New I didn’t find a outlet to purchase it from.
Missourimark is offline   Reply With Quote
Old 01-31-2018, 12:50 PM   #3
Keystone_Hate
I am actually dealing with this as well. Just yanked my seat last night. If you look at them, they are just standard zig-zag upholstery springs. I am going to get a foot of the spring from a local upholstery shop and give it some quick bends and secure it in there with the little sheetmetal c-clip things. I am gonna do this today and I can report back later this evening and let ya know how it goes.
Keystone_Hate is offline   Reply With Quote
Old 01-31-2018, 12:58 PM   #4
cebra
Dealing with the same issue on mine as well so I will stay tuned.
cebra is offline   Reply With Quote
Old 01-31-2018, 05:19 PM   #5
Keystone_Hate
Well here it is. Buy two feet of no sag zig-zag spring. Extra for if you screw up. . Cut off about 6 inches of it and leave a little hook on the end to keep it in the clip and the frame. Use a cut off wheel or bolt cutters. Don’t stand on either end of it to flatten it out so you can fit the cutoff wheel in. It will let go like hell when you cut through it. Ask me how I know. Slide one end into the slot on the frame. Use your man strength to bend the other end over to where the old spring was attached. Get it close and use some vice grips to hold the end of the springs together where you're gonna put the clip. Clamp on a clip with some pliers. Whammy. No more butt sag. Now mine doesn’t feel perfect cause my foam is shot but at least I’m not leaning hard to the left when I sit on it.
Old 01-31-2018, 05:20 PM   #6
Keystone_Hate
Sorry for the sideways pics. I haven’t mastered that yet.
Old 01-31-2018, 05:22 PM   #7
Keystone_Hate
You can get fancy with it and do what ya please but this is the basics. And it works. For $4.03
Old 02-01-2018, 12:18 AM   #8
clay68c10
clay68c10's Avatar
Looks perfect
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-01-2018, 06:37 PM   #9
68Gold/white
Attachment 1746217
Attachment 1746218
Attachment 1746219
Mucho Thanks!!!
I have like 4 seats (for my 2 pickups, 1-67, 1-68...LOL) The cushion foam is totally screwed on all 4.
An inexpensive foam repair is the next miracle I'm looking for!!! I'm not likely to pay the $350.00-$500.00 for a piece of foam!!!
68Gold/white is offline   Reply With Quote
Old 02-01-2018, 09:11 PM   #10
Keystone_Hate
No problem. And yes precut foam is ridiculously priced. BUT big chunks of foam from an upholstery shop is not expensive. Look into it man. You can get different density and layer it if ya want. Hell, the shop you buy it from may even carve it up to match your old one, most likely for a fee, but probably a lot less than buying premade stuff. I'm not an upholsterer, but I have done a lot more complicated **** than carving a block of foam. I'm gonna give it a shot one of these days.
Old 02-01-2018, 09:15 PM   #11
harpo231
harpo231's Avatar
Take your time and use a hacksaw , works good
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-01-2018, 09:41 PM   #12
Keystone_Hate
I have heard an electric turkey carving knife works well also. Or you can make a foam cutter out of a motorcycle battery and some single strand wire.
