Old 01-31-2018, 08:05 PM   #1
gsharp
Six lug front rotors
After alot of checking I have found that there are no 1" thick six lug rotors. So since mine are new five lugs and everything else is new too I think I'm going to get them plug welded and drilled for six lug. It is six lug x 5" circle correct? What size studs?
gsharp is offline   Reply With Quote
Old 01-31-2018, 08:33 PM   #2
PGSigns
PGSigns's Avatar
Re: Six lug front rotors
You may want to rethink the welding. The rotors may be cast iron. You can do press in plugs. The bolt pattern is 6X5.5.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-31-2018, 08:36 PM   #3
gsharp
Thanks Jimmy. Do you know what size studs are?
Old 01-31-2018, 08:57 PM   #4
PGSigns
PGSigns's Avatar
The ones in my rotors are 1/2X20. Stock ones are 7/16X20. The holes are drilled to match the studs you choose and the back sides are spot faced to give the studs a flat seat. If you do a search here you will find several threads on drill rear axles and what holes overlap. Not many on rotors.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
