Old 02-01-2018, 12:43 AM   #1
un4gvn!
un4gvn!'s Avatar
Concave washers
ISO; I'm looking for the thick washers that go on the studs before mounting the upper control arm on a C10. C20 and C30 are totally different. You put the shims on after you mount the shaft. Any help would be appreciated. The picture shows the guys thumb holding it. Thanks
un4gvn! is offline   Reply With Quote
Old 02-01-2018, 01:09 AM   #2
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Re: Concave washers
Try the search box at the top right of this page,you should find something.If not try want to buy page in parts for sale.Then try Mc,Master-Carr cataloge. They have concave washers in all sizes.Hope this helps.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 02-01-2018, 06:19 AM   #3
OL SKOOL
OL SKOOL's Avatar
Re: Concave washers
I found these on ebay. I never did order them. I believe it was P.O.L
OL SKOOL is offline   Reply With Quote
Old 02-01-2018, 06:48 AM   #4
Killer Bee
Killer Bee's Avatar
Re: Concave washers
not sure if these are what fits your application but the shape you are referring to is common to a Belleville washer..
belleville washers however are typically designed with a spring property to them so I don't know if that applies to your application or not..
McMaster-Carr refers to them as Belleville Disc Springs and dimensions are listed on the left margin..
good luck!
Old 02-01-2018, 09:00 AM   #5
un4gvn!
un4gvn!'s Avatar
Re: Concave washers
Those aren't thick enough. I'm pretty sure mine were 1/4 inch. Thanks any how.
Old 02-01-2018, 11:07 AM   #6
sprint_9
sprint_9's Avatar
Re: Concave washers
http://67-72chevytrucks.com/vboard/s...d.php?t=589541
They are referred to as Spherical Washers, this is an excellent thread to read.
sprint_9 is offline   Reply With Quote
Old 02-01-2018, 11:34 AM   #7
Killer Bee
Killer Bee's Avatar
Re: Concave washers
^ ah, spherical washers.. seen those before and never knew the proper name.. thank you!
haven't read that thread yet but McMaster-Carr has them too
Leveling Washers
Also known as spherical washers, these consist of a male and female washer that, when nested, swivel slightly to compensate for tolerance variations and uneven surfaces. They're good for die and fixturing applications.
good luck!
