Old 02-01-2018, 12:46 AM   #1
Jason7121
Jason7121's Avatar
4l60e cooler line flow
What direction is everyone running there 4l60e lines to the radiatior. I was told bottom line on trans is discharge and goes to top of radiatior and top line on trans is return and goes to bottom of radiatior. Curious how everyone is doing theres
Jason7121 is offline   Reply With Quote
Old 02-01-2018, 01:46 AM   #2
87Skier
87Skier's Avatar
Re: 4l60e cooler line flow
It doesn't matter, but I put the hot side (being pumped out of transmission to cooler) on the higher port of the cooler, and the return side on the low side. The thinking here is that it doesn't need to be completely full for fluid to get back to the transmission if the cooler isn't completely full.
Really it shouldn't matter though, since having a empty cooler would mean that the ATF isn't being cooled, but I would rather the transmission has enough fluid to operate than to worry about it being low on fluid and the fluid being too hot.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 02-01-2018, 02:05 AM   #3
Jason7121
Jason7121's Avatar
Ok I figured if hot out is pumped to top of cooler it would return easier on bottom of cooler back to trans
Old 02-01-2018, 03:18 AM   #4
54Caddy
GM Addicted
54Caddy's Avatar
Lower line on trans to lower on radiator, upper from radiator to inlet on external cooler, then outlet to upper line on trans. If no external cooler than upper from radiator to upper on trans. Routing it opposite way could cause aeration in fluid. And we all know that’s not good for your transmission
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 02-01-2018, 10:25 AM   #5
Jason7121
Jason7121's Avatar
Monster transmission told me opposite of that lower line at trans is hot out and goes to upper on radiatior.
Old 02-01-2018, 10:36 AM   #6
ga-stepside
ga-stepside's Avatar
The upper transmission fitting is the return from the cooler into the tranny.
The lower transmission fitting is the outlet from the tranny to the cooler.
So- OUT the bottom, IN the top.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 02-01-2018, 10:37 AM   #7
Jason7121
Jason7121's Avatar
In the top of radiatior correct
Old 02-01-2018, 12:11 PM   #8
davepl
davepl's Avatar
It varies by transmission and it does matter, I'm told. TH400 is backwards from 200-4R, for example. 4L60E return is on the top. 4L80E is on the lower. And so on...
Any blanket statements about which way it goes without being specific to your model of transmission has about a 50/50 shot of being right.
USUALLY though, and this is a gross generalization, I've noticed that they're typically laid out so that the lower port goes to the lower port on the radiator. That might not be 100% though!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-01-2018, 12:28 PM   #9
Jason7121
Jason7121's Avatar
Yeah it shows return port is top fitting on trans which means it goes to bottom of radiatior is how I take it
Old 02-01-2018, 01:22 PM   #10
Bigdav160
Bigdav160's Avatar
The top of the radiator is the hottest and the bottom the coolest.
In newer car tech, they use hot transmission oil from the converter to warm the radiator up faster to control exhaust emission sooner.
In my truck the hot oil from the transmission goes into the top fitting on the radiator.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-01-2018, 01:36 PM   #11
54Caddy
GM Addicted
54Caddy's Avatar
Look at your crew cabs lines and route the same way. I’ve always routed the way I’ve stated with no issues.
..Mac’s Garage..
IG:MacsGarage
Old 02-02-2018, 02:49 AM   #12
Jason7121
Jason7121's Avatar
Everyone says different things I did find this image and think I'll route them this way.
Old 02-02-2018, 12:48 PM   #13
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's another diagram.
It shows the hot from the trans to the bottom of the radiator,then to the bottom of the cooler and out the top of the cooler and back to the top of the trans.
The hot fluid from the trans is going to the cooler port on the radiator and then out the top of the radiator through the external cooler back to the transmission.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-02-2018, 02:02 PM   #14
Bigdav160
Bigdav160's Avatar
Just confuse this topic further I have this quote from an automotive manual I have:
If installing an additional transmission cooler onto a vehicle, the lines should be set up so the fluid flows from the converter to the add-on transmission cooler in front of the radiator. From the add-on cooler, it should flow to the factory heat exchanger in the radiator before returning to the transmission. This arrangement allows the fluid to warm up in cold operating conditions to prevent excessive transmission wear and harsh shifting.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-02-2018, 02:11 PM   #15
ga-stepside
Another thing I found when I installed the coolers in my cars and the truck.
Orientation as follows:
1967 C10 Step side
1970 AMX 390
Old 02-02-2018, 02:42 PM   #16
LH Lead-Foot
I always found it was interesting that 200+ degree coolant is cooler than a transmission. Unless you are pulling, towing or hitting the metal under the pedal, it is a good idea to have a cooler. Since the top of the radiator get the engine hot coolant, make sense to run the red juice into the top of the radiator's internal plate cooler, to the bottom, where cooler coolant lives, out to cooler, then back to the transmission. For those of us who live on the North side of global warming (We called it weather when I was younger), I think I have seen a bi-metal valve that helps to keep the fluid from getting to cold...or is that even possible unless your cooler is the size of an old A/C condenser. Thoughts?
LH Lead-Foot is offline   Reply With Quote
