Old 02-01-2018, 03:26 PM   #1
Droff
Aluminum Wheels
I bought my '68 with the aluminum wheels in the pic and was told they were Duramax wheels. No reason for me to doubt it but I don't know much about Duramax wheels. I need some lug nuts and not sure on size, the ones I have now are a bit sketchy as far as fit goes but they've held the wheels on.
Any info on what year these wheels are or would that matter? I'd prefer lug nuts a little less large/long and have a few websites to shop at but I don't want to order something that won't fit correctly.
Also, I have a Dana rear with the stock drums, I 'think' the threads are 9/16"-18 but not positive. I have rotors from an '86 3/4 ton on the front now, what would be their size? The lug nuts I currently have will not thread onto the bolts.
Thanks.
Droff is offline   Reply With Quote
Old 02-01-2018, 04:02 PM   #2
demian5
demian5's Avatar
Re: Aluminum Wheels
The make what is called a "conversion lug". Had to buy some to put a set of these on my son's 86 C20.
Look on eBay.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-01-2018, 04:14 PM   #3
Barnfind46
Barnfind46's Avatar
Re: Aluminum Wheels
I have those wheels. I bought lugs to fit my studs on the '68 and still hold the center cap. Then I up graded to later model '85 front disc brakes and bought a set to fit that. Then I up graded the rear end to a 2002 14 bolt. Had to buy metric. Ended up with three sets of lugs.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 02-01-2018, 04:41 PM   #4
Droff
Re: Aluminum Wheels
So do you know the size you bought that also held the center cap? I'm leaning toward a center cap as well, which I don't currently have.
I'll look into a 'conversion lug' mentioned.
Thanks.
Old 02-01-2018, 05:08 PM   #5
LONGHORN1962
LONGHORN1962's Avatar
Re: Aluminum Wheels
86 rotors will have 9/16x18. Usually 68 model has 1/2x20 studs.
LONGHORN1962 is offline   Reply With Quote
Old 02-01-2018, 05:30 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Aluminum Wheels
Those are the exact stock wheels that are on my '06 Silverado K2500 HD. It's also not a Duramax truck.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-01-2018, 05:53 PM   #7
Droff
Re: Aluminum Wheels
Thanks for that. Now to go find some caps and nuts.
So maybe not Duramax wheels?
Old 02-01-2018, 10:30 PM   #8
Re: Aluminum Wheels
The Duramax is a diesel engine option. Wheels don't come with an engine option, they come with a trim package or an option themselves. Those are '99 till recent GM 2500/3500 wheels. They came on OBS trucks as well. My friend had a 2000 K2500 6.5TD that came with them.
Old 02-02-2018, 08:08 AM   #9
Keith Seymore
Keith Seymore's Avatar
Re: Aluminum Wheels
This is exactly correct.
RPO PY0.
(I have two sets for my '04 ).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-02-2018, 09:17 AM   #10
Droff
Re: Aluminum Wheels
Any suggestions on a lug nut style to use with a center cap?
Old 02-02-2018, 11:43 AM   #11
demian5
demian5's Avatar
Re: Aluminum Wheels
XOXO
https://www.ebay.com/itm/32-LUG-NUTS...VWD11e&vxp=mtr
https://www.ebay.com/itm/20-LUG-NUTS...tWD~Gz&vxp=mtr
1986 C20 Scottsdale
Instagram: C10sofOC
