02-02-2018, 04:11 PM | #1 |
1985 Silverado speedometer cable problems
My real nice '85 Silverado has 230,000 miles on it and the speedo cable keeps coming apart according to my local rural mechanic. I was told a couple of times that the cable is in two sections and that they separate, rendering the speedometer useless. I checked most of my usual supply houses for parts without success. Have any of you had speedo issues with cables and the parts necessary to change the speedo readings when the rear axle ratio was changed ? This is a first for me and I don't have a clue what I am talking about. Thanks for pointing me in the right direction.
RIDING.....a sure fire way to relieve cattle ranch burnout! '85 C10 Silverado LWB & 350/700R |
02-02-2018, 04:26 PM | #2 |
Re: 1985 Silverado speedometer cable problems
what kind of setup in your 85, 2wd or 4x4, auto or manual? they list a bunch of different cables depending on the setup.
LMC truck lists prob close to 5 or 6 cables for a 1985. Also they do match little ratio adapter boxes to adjust if you change the rear axle, what swap did you do? |
02-02-2018, 10:38 PM | #3 |
Moderator
The drive and driven gears can be changed fairly easily. Usually, but not always, you don't need the ratio adapter.
Roughly ten or a few more pages of 1985 speedometer gear charts can be found in the 1985-1991 GM Light Truck parts books starting on page 4-117. Download them from the manuals post in my signature... or read them Online here http://gmpartswiki.com/getpage?pageid=58504 You'll need the tire size and axle ratio along with the transmission or transfer case type.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-03-2018 at 01:02 AM. |
02-05-2018, 10:44 AM | #4 | |
My 85 is a 2x2 with a 700R automatic. I went from an original 3.08 to a 3.73 rear gear for pulling purposes here at the ranch. LMC is one of the supply houses that I did not check with, so thanks, Tiger Joe.
02-05-2018, 10:47 AM | #5 | |
02-05-2018, 11:40 AM | #6 |
LMC lists both the upper and lower for your truck
Advance auto lists upper and lower as well: ATP cable- Y-814 upper Y-808- lower if advance's website is correct |
