02-02-2018, 05:17 PM | #1 |
Rust encapsulator not turning black
So I used some naval jelly to clean out some rust in my rear cab corners because I couldn't get to it with any kind of scraper. I then rinsed it off and let it dry and sprayed on some 3m rust encapsulator that was supposed to turn black within 20 minutes but it never turned black. What did I do wrong? What should I do?
02-02-2018, 05:40 PM | #2 |
Never Ending Projects
Re: Rust encapsulator not turning black
Did the naval jelly remove the rust? The rust converters need to have actual rust to convert (turn black). If you don't have any and it's clean, bare metal, I don't think it does anything.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
02-02-2018, 05:47 PM | #3 |
I think it still had rust I will have to check again this saurday.
02-02-2018, 05:52 PM | #4 |
Mike is right. Most rust converters/encapsulators rely on the rust. Sometimes, if there is just clean metal, the rust treatment will turn light grey or white.
02-02-2018, 07:58 PM | #5 |
For me, Rust encapsulator, seems to nothing more than thick enamel paint.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
