Old 02-03-2018, 03:17 PM   #1
72farmer
need help finding a/c compressor wires on 85 GMC
I have a 85 GMC Sierra Classic.I am going to try to get the a/c going.I can't seem to find the wire going to the compressor.The compressor has 2 wire terminals on it.I thought most older vehicles that had a/c on them only had 1 wire to compressor.The negitive ground was done through engine ground and mount.
I need to know what color wire or wires would come from pressure switch and go to the compressor.
72farmer is offline   Reply With Quote
Old 02-03-2018, 08:11 PM   #2
natedogg
Re: need help finding a/c compressor wires on 85 GMC
The wires are green. As you can see, the a/c compressor has its own Lil harness that branches off. Went out and snapped a pic of the Lil harness on my 85. I think I have a extra harness out in my garage, if you need?
natedogg is offline   Reply With Quote
Old 02-03-2018, 08:23 PM   #3
gmachinz
The AC subharness on the right in the pic is the one you need. The dark green is compressor clutch +12V and the light green wire goes to carb idle stop solenoid. The AC comp clutch negative grounds to your thermostat housing bolt.
gmachinz is offline   Reply With Quote
Old 02-03-2018, 09:05 PM   #4
72farmer
Thanks for the help.I found it.
Old 02-03-2018, 11:15 PM   #5
Wwes
Anyone know what year they had a high-pressure switch on the back of the compressor?
Wwes is offline   Reply With Quote
