Old 02-03-2018, 10:46 PM   #1
Blue Bowe-ty
Tilt steering columns
I was wondering what used tilt steering columns would plug and play on a '71 3/4 chevy if you can't find an Original?
Blue Bowe-ty is offline   Reply With Quote
Old 02-03-2018, 10:58 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Tilt steering columns
72-80 van will bolt right up. You just need to collapse your intermediate steering shaft. Relocating the neutral safety switch is simple and straightforward. You will need a horseshoe adapter for the turn signal switch to plug in. If you can find a motor home column up through 82 your steering shaft won’t need to be collapsed. These columns do not have a key, same as trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 02-04-2018, 02:58 AM   #3
bbrriiaann1973
Buy a replacement from a aftermarket
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-04-2018, 03:26 AM   #4
bennylava
bennylava's Avatar
Those things are real expensive, but they are what I'd try to go with as well. Unless its some kind of huge pain. If the van ones bolt right up, that may be a better idea. But I'd do what I could to rebuild the van one while it was out. Address any slop anywhere.
bennylava is offline   Reply With Quote
Old 02-04-2018, 08:00 AM   #5
bbrriiaann1973
Yes mine was pricey but it was bolt right in, all new, connectors plugged right in.
I paid more so I didn't have and or less headaches
Brian Ritter
Old 02-04-2018, 09:58 AM   #6
Blue Bowe-ty
Thanks for the advice
Old 02-04-2018, 09:59 AM   #7
Blue Bowe-ty
been thinking about new just don't have the funds just a lot of time,,thanks for your reply
Old 02-04-2018, 10:00 AM   #8
Blue Bowe-ty
thanks
Old 02-04-2018, 10:00 AM   #9
Blue Bowe-ty
thanks
Old 02-04-2018, 10:08 AM   #10
Blue Bowe-ty
that's the info I needed as I am on a tight buget,,,,Thanks,,,from a former Ventura County Guy
Old 02-04-2018, 10:27 AM   #11
bbrriiaann1973
My thoughts about the steering column when mine needed to be replaced was that I could fine one that fit out of another truck, van, car but those would be like 30 to 40 years old and in just as bad a shape as mine.
Then once you get it home and realize it needs to be repaired your at the cost of a brand new one that drops right in!
Brian Ritter
Old 02-08-2018, 12:39 PM   #12
bennylava
bennylava's Avatar
...I could fine one that fit out of another truck, van, car but those would be like 30 to 40 years old and in just as bad a shape as mine.
Yeah I've run into that plenty of times. You'll get a lot of people saying to rebuild this or that, and that its a waste to buy new. Until you factor in all the time and trouble, and the cost of the parts required to rebuild it. Maybe in the end you paid more for that new part, but boy did you save yourself a lot of hassle.
Old 02-08-2018, 01:26 PM   #13
PTC002
Which brand of new ones? Seems there have been a lot of complaints about the new ones.
PTC002 is offline   Reply With Quote
Old 02-08-2018, 01:34 PM   #14
leddzepp
Moderator
leddzepp's Avatar
If you are buying aftermarket go with flaming river or ididit. They are very pricey, but the $300 new ones made overseas have a LOT of complaints. This is why I recommend a van column for people on a budget. Way less expensive and still oem GM quality.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-09-2018, 02:48 PM   #15
dell72
I converted my 69 C10 from 3OTT to an automatic using a column from a 78 G20 van. As others have stated this was a cheap alternative compared to a new aftermarket piece and it only required minor modifications to bolt in. I found the horse shoe wiring adapter on Rock Auto. Generally the only items that are replaced during a rebuild are the turn signal switch and the upper and lower bearings. All of these items are fairly inexpensive and easy to replace.
dell72 is offline   Reply With Quote
Old 02-10-2018, 09:14 PM   #16
Baker72chevy
What black do I to us to paint my column with
Baker72chevy is offline   Reply With Quote
Old 02-11-2018, 01:19 PM   #17
dell72
I've used Duplicolor low gloss black in the past on other vehicles. It seems to have the correct OEM sheen.
Old 02-11-2018, 02:38 PM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Van tilt column install:
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Rebuilding a tilt column:
http://67-72chevytrucks.com/vboard/s...d.php?t=329008
Another tilt Installation:
http://67-72chevytrucks.com/vboard/s...d.php?t=133937
A little info on the Motor Home tilt:
http://67-72chevytrucks.com/vboard/s...d.php?t=134391
LockDoc
Leon
Old 02-11-2018, 04:00 PM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Is the motor home tilt angle different than a pickup?
The one in my truck seems only to go down and no up at all.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 02-11-2018, 04:11 PM   #20
72 tigger
72 tigger's Avatar
I thought the vans went with a column ignition in 78?
72 tigger is offline   Reply With Quote
