02-04-2018, 11:53 AM | #1 |
Quality of AC Delco Parts?
I'm doing a lot to my truck right now to get it where I want it. Suspension, brakes, engine swap, drive line and so on. I have been trying to get mostly AC Delco parts when available, because, from what I understand they were the original manufacturers for a lot of GM stuff. BUT I have been really disappointed lately. I got a reman alternator and the top hole for the adjustment bar was tapped to fix stripped out threads then had a metric bolt jammed into it, all but destroying the threads. It also has a metric nut for the battery wire, and the fan is a little wobbly. I also got some reman calipers for the front and both of them had damage to the rubber around the piston seal. One of them the seal was not even pressed into the caliper the entire way.
Has anyone else had these issues with AC Delco reman parts? Any suggestions for better brands? I imagine they all come from the same place, just in a different box. I don't have a limitless budget so I'm trying to get quality stuff at regular working dude prices. |
02-04-2018, 11:57 AM | #2 |
Re: Quality of AC Delco Parts?
AC/Delco used to mean something a long time ago but seems like now everything is just reboxed junk from the same place .
02-04-2018, 12:01 PM | #3 |
Carpe manana
The new AC Delco R44t plugs I just received were made in China. No thanks. Fortunately, US made NOS examples can still be had on eBay for a reasonable price.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-04-2018, 12:04 PM | #4 |
The AC Delco brand is owned by GM. The manufacture of the actual parts is subcontracted to a supplier who is supposed to make the part according to GM's specifications. That being said, you should get an OE quality part , should !! that's not always the case,,I like napa premium line,but some say they made by same company as ac delco
Stan 67 swb BLU MULE posted via flip-fone |
02-04-2018, 12:12 PM | #5 |
02-04-2018, 12:40 PM | #6 | |
My engine builder thinks I'm a but kooky running NOS spark plugs...
02-04-2018, 12:45 PM | #7 |
Carpe manana
Then I'm a kook also. I'm buying and shelving US/Canada Delco or equivalent replacement parts for any future need. Two years ago I got US made Napa air filters - now outsourced to Mexico. I just got a batch of NOS gas filters for Qjet for less than the new India-made examples.
02-04-2018, 12:48 PM | #8 |
There are some 50 yr old parts it just don't make sense to use ! Plugs ok long as ceramic not cracked ...ya gotta use good judgement ..
02-04-2018, 01:11 PM | #9 | |
02-04-2018, 01:18 PM | #10 | |
ACDelco is not the same company as AC Delco. From Wiki:
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
02-04-2018, 01:23 PM | #11 |
02-04-2018, 01:29 PM | #12 |
That is interesting, I never knew that. I've tried to stick with ACDelco when I'm replacing parts and not looking to upgrade. I figured, if they were good enough for GM 50 years ago, they should still be at least as good, if not better with the advancement of technology. Now I know that isn't necessarily the case! I have noticed that the ACDelco parts I buy always seemed to be repackaged, like the brake lines I just bought that say Sunsong on them...
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
02-04-2018, 01:49 PM | #13 |
just for the heck of it went on rock auto...and clicked on a couple acdelco chevy parts...when you hit "info" some of them come up as ''GM original part" but many do not....they even list acdelco suspension parts for volkswagens....
1970 short step c10 leaf spring 454 |
02-04-2018, 02:04 PM | #14 |
Many companies have found the burden of regulation, competition and market share, much less profit margins dwindle over the years. Maytag & Bluebird Bus company has moved from Iowa into Mexico...Sad! In full discloser, I was a contract labor for ACDelco for 7 years. I saw them having no choice in many cases a even Delphi was in reduction mode and sources of suppliers dried up in the states. I was part of a group of 50+, who went thru a re-man rotating electrical supplier, in the states. When moved from station to station to impress upon us the quality, I noticed strange things. The guys in quality control where pretending to measure, writing down their findings and moving on. But looking over their shoulder, I found the employee pretending to write anything new down...just moving the pen over the paper. Then pallets of product to be shipped, I climbed up to racks to find empty boxes. Mean while, management was going on a trip. Where? Across the boarder to see the new plant that employed workers for 20% of what is cost them in the states. I can't blame GM or ACDelco, it's just the cost of labor, healthcare, retirement, union pressure and other things has forced companies out of the U.S. While all manufactures of vehicles I have worked on, at dealers, have two or more vendors supplying parts in case one has labor issues, material issue, political conflicts and transportation problems, has forced plants & vendors to try harder to get that contract and produce parts to specs. ACDelco has a professional series, that is a higher grade, but each can have issues. As for myself, anywhere you go, the local part stores, little is made in the states. GM found a huge market in China for the production of certain Buick & Chevrolet vehicles...Then the TECH2 from china started to hit eBay. Copies that are not well made. It is true, the quality of certain parts is questionable and when good, have a vendors name on the product from NGK, to whoever. GM was selling vehicles and parts in over 67 countries, so some of this is to be expected. I will still go for ACDelco parts and deal with a defect when I cross that bridge. I have seen the flat-rate customers pay go from $6 per hour to $23, then $28 and now, the Master Tech has no retirement and makes less than 20% of the flat-rate. That also is sad, but too many get their cut, before a profit margin is seen at the shop or dealer. How many new tire machines or alignment systems have you seen over the years? They are not getting cheaper either, so cost is past along.
02-04-2018, 03:07 PM | #15 |
As long as the corporate tax laws remain the way they are and the companies emphasize corporate globalization and GE pays less in taxes than I do,you may as well get used to it....
02-04-2018, 04:50 PM | #16 |
laying low
It's hard to guess right each time when buying new parts, one brand or another. I have long been a GM owner and when I could I bought AC Delco replacement parts. Some times AC prices at the parts houses were way out of line so I would buy another brand but I always stayed away from the more generic off brands. I tried to stay with the middle priced brands.
In AC's defense. I needed a brake light switch for my 09 Yukon as the cruise had quit working. Available at the parts store was an AC switch for $19 or a Borg Warner for $38. hmmm. At twice the price I reasoned the BW might be a better switch so I bought it since this is my wife's vehicle and she is on the road a lot. I installed it and all was fine. For one week. Numerous dtc's began to appear and the brake lights began staying on and the cruise was inop once again. DTC's for traction control and things like that were there. Fearing terrible things I sent the truck to a dealer's garage who replaced the BW switch with a Delco one and all was good once again. They also remarked at the failure of the BW switch and it's twice higher price than the Delco. It's been two years now and still working. Last week I bought an AC window switch from Rockauto. It arrived and the label said AC Delco and made in Taiwan. It was listed as one for the left rear window location and was the only one I found available for that window. It arrived and did not fit. It was not correct for the left rear window. Fortunately I was able to disassemble the switch and move the good inner parts to my old one and all is well. One has to wonder what folks on the other side of the world go through in maintaining their vehicles. Are they going through the same issues we are?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-04-2018, 05:13 PM | #17 |
They dont need parts they drivin hondas and toyotas.....
02-04-2018, 10:09 PM | #18 |
The only acdelco part is the box. I seen acdelco napa and pep brothers rebuilt alternators, identical in absolutely every way except the install booklet and the box. the plastic bag and the inspectors decals ect, were identical. there was about a 23 dollar difference in the price. to save a bunch of pennies on shipping they would sell out thier reputation.
02-05-2018, 02:16 PM | #19 |
I posted on this earlier, but let me make this clear. GM uses ACDelco parts during the assembly of vehicle on the line today. The difference is when the vehicle was under warranty, parts that failed where turned in while other where requested. Engineering test for workmanship, components and design. If a problem found regarding the later two, the part was re-designed with different materials or what ever. The end result, other copies the original to be competitive...it the old design. So, second design is issued, part number changes, sometime the price. This equates to a part the will last and work better. Parts and the components used in them have requirements, the main one being 5000 hours of trouble free usage. This is 150k mile on a vehicle. I will buy that part anytime. GM vehicles I work on at the dealer had three or four items that failed early on, the replacements where different in color, part number or other markings. But once installed, they never failed again. Failure to install properly or maintain is the death of any part. Yes, 3 miles of wire is found in a 93 Corvette, while the 2018 Vette does more and has 1.7 miles of wire, mostly 20 AWG. The use of serial data communications allows a service tech to use the diagnostic flow chart & scan-tool to quickly diagnose the fail part. This architecture is used all over the world, in every GM vehicle. The price of parts cannot be controlled, the cost of labor to change a part cannot be controlled, but the time spent diagnosing the root cause-fail part is reduced and more accurate. The aftermarket parts share of any company is brutal, but I will buy from the ACDelco professional parts line every time.
02-05-2018, 02:39 PM | #20 |
Moderator
I think overall quality of outsourced parts has improved. I buy most everything at autozone, if they don’t have it they can order it. The last electric window regulator I bought for my 01 Yukon was made in India and I was very impressed with the quality and fitment. The price was reasonable as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-05-2018, 02:43 PM | #21 |
This exact conversion and thread could be applied for almost any american product anymore...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-05-2018, 02:46 PM | #22 |
Moderator
It does, and it comes up here ALL the time
02-05-2018, 03:40 PM | #23 | |
Also my wife has an '07 Pontiac G6 bought new. It has 236K miles. Never had an alternator, water pump, starter, a/c compressor, or anything. It needed both front wheel bearings at about 100K and have had issues with the exhaust manifold cracking but that is not a lot of parts for that kind of mileage. Neither have ever had a catastrophic failure that left us stranded in these 2. My point is that GM is building some good cars now. I have worked on Hondas and Toyotas too. Alternators and water pumps don't last forever on any make. Even the bulletproof Toyota 22R engine will fail if you run it out of oil. Every dealership has a service department, none are immune. Good maintenance is the key to long life of any vehicle.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-05-2018, 04:42 PM | #24 |
,Lexus[a toyota] ,kia, honda.Toyota, in top ten Porshe and Buick round it out for least service,,,
Ya don't have to like it,, but it's true
Stan 67 swb BLU MULE posted via flip-fone Last edited by harpo231; 02-05-2018 at 04:51 PM. |
02-05-2018, 04:47 PM | #25 |
Moderator
I agree. I own an 01 Yukon and an 03 4Runner. I’ve replaced nearly EVERY part on the Yukon over the years. I’ve replaced the gas cap on the 4Runner There is absolutely no comparison. I only own the Yukon because it can haul more people.
