02-04-2018, 04:42 PM | #1 |
Ordered new wheels now trying to get an idea of tire size
I have a 85 c10 - up front (springs/drop spindle) and a flip kit in the rear (no c notch)
I ordered US Mags 20x8 for the front and 20x9.5 for the rear. I looked through tons of threads and am having a hard time coming up with the right tire. I want a little more beef in the rear but not too much to make it look akward. Anyone have any thoughts? I dont want to take out or modify my front fenders either - just want to do it right the first time. Currently I have 275/50-15 rear and 225/60-15 front (the fronts are a bit too small)
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 02-04-2018 at 04:45 PM. Reason: added pic |
02-04-2018, 08:17 PM | #2 |
Re: Ordered new wheels now trying to get an idea of tire size
I used this chart to help me when I was shopping for tires:
https://tiresize.com/chart/ Stock diameter tires on our squares (2 wheel drive) were right around 29", so that's what I looked for on the rear. Up front, I went with something like 27.6 tall, since I wanted a bit of the "big and little" look... |
02-04-2018, 08:57 PM | #3 |
02-05-2018, 01:09 AM | #4 |
yep, I have used the tire size chart to compare sizes but, looking for advice on too big, too small, too much side wall bulge... mainly what works for people so, I know it will work for me.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
02-05-2018, 03:25 AM | #5 |
I have US Mag Ramblers in that size. 245/45-20 and 275/40-20. 2.5 spindle and one coil cut up front and a flip in the rear with no notch. I love the tire height combo.
You’d probably want to go slightly bigger in the rear if you want it a bit beefier.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
02-05-2018, 10:17 AM | #6 |
I run 285/50/20 on the rear of mine on a 20" x 10" wheel
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
02-05-2018, 11:50 AM | #7 |
Right on, thanks. I was thinking a 245/45 up front and maybe a 295/40 in the rear... u think the 295 may be too wide for the 20x9.5 outback?
02-05-2018, 12:03 PM | #8 |
I'm running 245/40/20 on a 8" wheel up front on mine. 295 is just a smidge wider, you may be able to get away with it.
295/40 is 11.6" versus a 285/40 at 11.2". I have barely enough room to fit two fingers between the inside of my tire and the wheel well. I could probably get away with a 295 but just haven't tried yet.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" Last edited by 77c10; 02-05-2018 at 12:09 PM. |
02-05-2018, 02:38 PM | #9 | |
295/40-20 = 29.29" tall. On a 9.5" wheel you would be @ 1.10" of tire per inch of width. Spot on.
02-05-2018, 07:07 PM | #10 |
Nobody has mentioned back spacing and that will be critical for wheel tire fit.
02-05-2018, 07:53 PM | #11 |
With those wheel sizes on a square w/a mild drop I would recommend 4.5"bs front & rear.
02-05-2018, 08:09 PM | #12 |
I have riddler wheels don't rember back space ,I think they only come one way, have 8.5 on front and 10,s on back, I have 2.5 drop spindles and 1 inch springs rear leafs are flipped I first put 245 45 r20 on front and 295 45 r20 on rear in first pic, I changed tires today went with 275 45 r20 on front and305 50 r20 on rear in second pic hope this helps, I to was confused on tire size but I got the combo I was wanting now
02-05-2018, 08:21 PM | #13 |
That combo in the second pic looks nice
02-06-2018, 07:23 PM | #14 | |
Thanks again. I personally like the first pic... why did you go taller?
02-07-2018, 12:10 AM | #15 |
255/40/20 fronts on 20x8 and 315/35/20 rears on 20x10s. Flipped rear and 2.5 inch spindles with 2 in springs. No rubbing anywhere. Pull my 18ft ranger bass boat with it too.
02-07-2018, 09:25 AM | #16 | |
02-08-2018, 11:00 AM | #17 |
Good looking truck! I really like the color combo! Thanks for the info.
02-08-2018, 11:31 AM | #18 |
02-08-2018, 11:43 AM | #19 |
So, in the end, I purchased U111 Rambler wheels 20x8 with 245/40 and 20x9.5 with 275/40 Nitto tires. Shipping to Hawaii is a little more but it came to 2k total (with shipping, mounting & balancing, and a new set of lug nuts). All in all not to bad. should be here in about 2 weeks. I got them from SoCal Custom Wheels and their customer service was AWESOME... they worked with me and found reasonable shipping options to Hawaii - not many vendors are willing to go that extra mile.
Just as a teaser - I ordered a FITech EFI set up for it! That should be fun! I will throw some pics up when I get the wheels here and on my Square (haven't named her yet - thats why I havent done a build thread).
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 02-08-2018 at 11:49 AM. |
06-02-2018, 03:15 PM | #20 |
