Old 02-04-2018, 05:21 PM   #1
leonphelps
91 sbc swap no second port for heater core
Hello,
Trying to figure out how to plumb my heater core. My engine is a 91 sbc from a caprice classic. There is only one connection for the core since the original car had a nipple on the radiator.
Saw this online, wondered if anyone else has a different solution? My radiator is brand new aluminum. Top hose is a flex hose one from napa. Bottom is a thick (1 3/4" I believe) hose. I need the 90 degree angle for the top hose. Pointing away from the engine would make the hose need to be another 12" long, and I dont like appearance of that.
https://www.ebay.com/itm/Racing-Powe....c100677.m4598
Thanks for any suggestions.
leonphelps is offline   Reply With Quote
Old 02-04-2018, 05:32 PM   #2
bama63
bama63's Avatar
Re: 91 sbc swap no second port for heater core
heater hoses go one hose to intake and other to top of water pump.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 02-04-2018, 06:04 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
As an example:
Old 02-04-2018, 07:13 PM   #4
72cs20
Is this an TBI engine? If so, look at the passenger side rear of the intake manifold and there should be a water port there for your heater core connection, along with the one on the water pump.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 02-04-2018, 11:36 PM   #5
Pontiacgurudan
If there is no hose fitting on your water pump there will be a plug you can remove and install the correct fitting. I had to do the same on my tbi motor in my 63.
Pontiacgurudan is offline   Reply With Quote
Old 02-05-2018, 10:27 PM   #6
66_c10_tpi
I had the same issue with my motor. It is a 92 TPI motor. The thermostat housing you are showing will not work. What I had to do is replace the water pump if my memory is correct out of a truck for the same year. If you have a serpentine belt system be sure and get a counter clockwise rotation pump.
66_c10_tpi is offline   Reply With Quote
