02-04-2018, 06:40 PM | #1 |
What headers are you using?
What are you recommending for a 65 small block with a 4 speed? I'd assume the auto headers are different because of the clutch mechanism
02-04-2018, 07:11 PM | #2 |
Re: What headers are you using?
I just bought some of of e-baaaaY for $120 for my 65 C10 with a 327. They were stainless and came with bolts, gaskets etc. I thought that was cheaper or at least as cheap as cermaic coating or painting my original ones.
02-04-2018, 08:29 PM | #3 |
Do you have a standard or auto?
02-04-2018, 08:53 PM | #4 |
I have the ram horns.
02-04-2018, 09:30 PM | #5 |
I have an auto with TH350 trans.
02-04-2018, 09:38 PM | #6 |
On my 1961 impala i have block huggers.
02-04-2018, 09:47 PM | #7 |
sanderson blockhuggers,283 mechanical clutch linkage
02-04-2018, 10:46 PM | #8 |
60-66 Nut
With a manual trans you will have to use either block huggers or Hedman 69260's. You can use Hedman 69090 or Hooker 2452 but those are a little tight around the clutch bellcrank.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-07-2018 at 02:33 AM. |
02-04-2018, 10:50 PM | #9 |
02-05-2018, 02:13 PM | #10 |
02-05-2018, 07:54 PM | #11 |
How do they affect the heat shields and plug wire routing that goes around the ram horns? Clear them?
02-06-2018, 02:04 AM | #12 |
60-66 Nut
The Hedman 69260's are the closest to rams horn manifolds. I do not know how the factory heat shields and factory routed plug wires would work as I have never run those with these headers.
02-06-2018, 03:21 AM | #13 |
I did the Hooker 2452 on mine with a TKO500 mated to a 350. Mechanical clutch, everything clears. Sounds really good, but keep in mind if you are lowered, or plan to lower, long tubes may not be a great choice. I have 2.5 inch drop spindles and if I'm not careful with speed bumps and some driveways I hit the headers. As long as I go slow over speed bumps I usually don't have a problem.
02-06-2018, 08:58 AM | #14 | |
