Old 11-03-2003, 07:33 PM   #1
rage'nrat638
rage'nrat638's Avatar
Thumbs up Front Windshield Install... Very Easy Thanks Gmc Paul
WELL DID JUST AS GMC PAUL SAID......
used the new rubber
used the rope
used the vaseline
used the caulk
went right in....
damn...i sure am glad everybody knows what i am talking about????
you might think it's got something to do with SEX..
used my son to give me a hand pushing and pulling......
man am i happy....
got the used windshield for 50.00 months ago...
rage'nrat638 is offline   Reply With Quote
Old 11-03-2003, 07:53 PM   #2
rage'nrat638
pics.
Old 11-03-2003, 08:09 PM   #3
Lobo'74
Lobo'74's Avatar
Instructions posted?
I need to put new rubber around my windshield. Have the rubber, but am approaching the task with some trepidation.
I intend to get the windshield out and clean/por15 the flange all around it, then try and put the new rubber and the old windshield back on.
Yours looks good from the pictures, are the instructions you used on the board here?
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 11-03-2003, 08:13 PM   #4
rage'nrat638
heres the link at pistons site
http://www.myoldtruck.com/forums/sho...ght=windshield
Old 11-03-2003, 08:32 PM   #5
Lobo'74
Lobo'74's Avatar
Post 101
woo hoo! 101 posts.
Thanks for the info on the instructions. I'm bookmarking it.
"Truck"
'67 small window
Old 11-03-2003, 08:32 PM   #6
Eddie H.
Eddie H.'s Avatar
How do you install the stainless steel trim that goes inside the weatherstrip?
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 11-03-2003, 08:40 PM   #7
Lobo'74
Lobo'74's Avatar
Whazat?
What is that big roll of black tape on your hood? Is it a good thig to have fot the instillation?
"Truck"
'67 small window
Old 11-03-2003, 08:41 PM   #8
rage'nrat638
install rubber into windshield....then install chrome trim....
getter all lubed up ...just the inside lip....vaseline
install rope...i put that tube type windshield caulk around the flange...then went to town....
had to do a little clean-up with prep-sol (don't eat paint)
BUT IT'S BETTER NOT TO HAVE ANY LEAKS
Old 11-03-2003, 08:54 PM   #9
68 Suburban
68 Suburban's Avatar
cool, you can do mine next time I come up :p
68 Suburban is offline   Reply With Quote
Old 11-03-2003, 10:32 PM   #10
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
You had allot better luck than I did. I broke two new windsheilds costing $125.00 each Im going to have one installed by a professional for $160.00 so Ill never install another windsheild ever
GMC JUNKIE TOO is offline   Reply With Quote
Old 11-03-2003, 10:47 PM   #11
gonebad2
Merciless Butcher
gonebad2's Avatar
I have installed about six or eight of them and only broke one(upper right corner). Thanks for the Vaseline trick. I'm going to try that one next time I install one. I just got a quote last week for a new windshield and was floored by the price. Only $110.00 installed. I paid $170.00 for the last one I bought. Isn't competition in business a great thing.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 11-04-2003, 12:40 AM   #12
Blue Beard
Blue Beard's Avatar
Nice job, going to do it for extra cash now........?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 11-04-2003, 02:23 AM   #13
ZOOMY
New Rubbers
Where did you buy the new rubber ? ( gasket ).......Thanks......Zoomy
ZOOMY is offline   Reply With Quote
Old 11-04-2003, 03:18 AM   #14
GMCPaul
I'll give you one hint where the gasket came from Glad you had a smooth and uneventful install!!!!
Heres the directions for anyone interested in doing it yourself.
Remove original windshield by cutting rubber on inside all the way around and push out and dispose ( far nicer than trying to pry it out with hole seal intact and it breaking and making a mess to clean )
After originals removed thoroughly clean flange inside and out where rubber seal rests and file off sharp edges to avoid tearing new rubber on install. Have new seal in a very warm area so is extremely pliable, lay new windshield face down on carpet or similar material and apply weatherstrip to glass, place a chalk line string ( available at Ace Hardware, Menards , Lowes, etc... ) in channel of weatherstrip where cab flange sits when installed leaving a small loop sticking out at the top center of rubber and other 2 ends of string sticking out bottom center, tape the top string loop and the ends of string at bottom in place to hold, then apply thin coating of vaseline to inside edge of weatherstrip that will be exposed on inside of cab when installed, coat cab flange opening with windshield chaulk and get assistance to lift windshield and place windshield in place from outside postioning upper angled corners in opening first then have someone inside cab begin pulling chalk string loop on one side of loop towards top corner while assistant outside cab applies light pressure to glass following progress of person in cab pulling the string, then work the opposite side top, then work string down either side, then pull center 2 ends towards outside bottom corners one side at a time. I find it works best when doing center bottom towards outer corner to grab end of string I worked from top down with one hand to prevent it from moving then I pull the end sticking out at bottom towards the corner, after seal is fully installed apply weatherstrip cement under outside edge of seal, then wipe down exposed area of seal inside and out to remove any vaseline or caulk on seal with acetone on a rag.
Slow and easy and a warm enviroment are the best when doing install.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-04-2003, 03:23 AM   #15
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Where did you get that quote for an installed windsheild? I haven't lookd around yet but, I figured $200 or more...
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-04-2003, 08:43 AM   #16
Huck
Huck's Avatar
NOW IF WE ARE DOING AN INSTALL WITH THE DELUX TRIM, IE THE RUBBER IS SLOTTED FOR THE STAINLESS WINDSHIELD TRIM, WHAT IS THE BEST PROCESS----INSTALL STAINLESS IN RUBBER BEFORE INSTALL OR AFTER AND HOW BEST TO DO THIS___________?? AND, DO YOU NEED TO GET A RUBBER GASKET THAT IS YEAR DEPENDENT---IE. THE 71/2 USES A DIFFERENT STAINLESS THEN THE EARLIER YEARS------??
Huck is offline   Reply With Quote
Old 11-04-2003, 08:54 AM   #17
GMCPaul
Install trim in rubber seal and make sure its fully seated in its groove then install rubber on glass and again make sure trim stayed fully seated in seal, then install windshield. Deluxe windshield seal with trim always use a 71-72 seal with 71-72 SS trim, and 67-70 always use a 67-70 seal with deluxe trim.
GMCPaul
Old 11-04-2003, 07:15 PM   #18
rage'nrat638
thanks again gmc paul
Old 11-04-2003, 07:24 PM   #19
guitarornothin
RUNN over AGAIN!!!
guitarornothin's Avatar
Re: Front Windshield Install... Very Easy Thanks Gmc Paul
GOOD DEAL FOR JUST 50 BUCKS!!!!!!
67-72 TRUCKS ROCK
70 SWB shaved and a 72 front clip.and a poly tank.
Peep mirrors and a BIG BLOCK 468 in the making.
XNXNXNXNXNXNXNXNXNXNX
,/. EMAIL ME HERE!, Dont pm me please
guitarornothin is offline   Reply With Quote
Old 02-14-2004, 04:53 PM   #20
68 Suburban
I assume it is the same trick for doing the side and hatch windows on a Burb? I am getting ready to paint the burb, and I would much rather paint it with the glass out.
Just sitting here contemplating contemplation.
Old 02-14-2004, 05:35 PM   #21
krue
Designated A-hole!
krue's Avatar
Thanks for the info! I put it in FAQ for future reference. I hope nobody minds.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 02-14-2004, 08:00 PM   #22
JJR
JJR's Avatar
What is the difference between the 67-70 and 71-72 trim? I have a couple of sets of windshield trim that I have picked up over the years and I can't remember what year trucks I got them off of. I believe they were pre 71's. When the time comes I don't want to order the wrong gasket. From what Paul said I am assumming the 67-70 is chrome trim and 71/72 used stainless steel. Is this correct? Thanks.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 02-14-2004, 09:05 PM   #23
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Not too sure about the stainless and chrome year's but from what I have heard the trim is a pain to put in and some glass shop's won't touch it??
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-14-2004, 11:16 PM   #24
rage'nrat638
INSTALL THE RUBBER ON THE WINDSHIELD.....
INSTALL THE TRIM........
I DID IT ON THE HOOD OF MY TRUCK W/A BLANKET UNDER IT...
NOT HARD AT ALL
