02-04-2018, 09:11 PM | #1 |
Dual muffler or single??
Thinking or running spintech mufflers on my c10 but trying to see what would be better if I run duals or singles... any suggestions?
02-04-2018, 09:29 PM | #2 |
Re: Dual muffler or single??
Single 3'' magnaflow in my 69. 454 automatic. Personally do not like headers or duals on a street truck. Did it when I was a kid.... got over it
02-04-2018, 09:45 PM | #3 |
Post Whore
Can you post some more info on the truck and how you plan on using it. Then folks can make a more informed reply.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-04-2018, 11:54 PM | #4 |
I run 2 1/2” dual exhaust with headers, an H-pipe and spin tech mufflers. I absolutely love the way my truck sounds. Not too loud at idle, but at wot it has a mean bark and I don’t experience any drone in the cab.
02-05-2018, 03:41 AM | #5 |
02-05-2018, 03:42 AM | #6 |
Any difference between running 2 1/2 inch pipes versus 3”? Does it make a difference in the sound at al, performance, etc...?
02-05-2018, 07:40 AM | #7 |
I have a 383 with headers and true dual exhaust and couldn't be happier. The louder the Better! Anything to piss off the neighborhood!
Brian Ritter |
02-05-2018, 09:55 AM | #8 |
Dual 2" is adequate on a stock small block - 2 1/2" with any kind of performance muffler should be ample. I prefer duals on a V8 - both my trucks had it before I got them.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
02-05-2018, 01:08 PM | #9 |
On a BBC the single gives you way more grunt.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-05-2018, 02:26 PM | #10 |
Location: Formerly MD and San Diego, now loving life in Arizona
On my built 396, I am using Hooker headers, a Black Widow X pipe, Flow Master 44's, and 3" pipe all the way thru that end behind the rear axle pointing down to the ground at a 45deg angle under the bed.
Very nice sound. No groan inside of cab at any RPM or speed.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
02-05-2018, 06:40 PM | #11 |
Mine has a 350 with stock manifolds. It's got really simple 2-1/2" duals exiting under the bed just ahead of the rear wheel wells. I like the sound.
They're just loud enough to help drown out the wind noise!
1970 C10 short stepside 350/700R4 |
02-05-2018, 08:21 PM | #12 |
When I had my '70 GMC with the 402 in it I was planning on a single 3" RV style muffler.
For my Jimmy I have dual 2 1/2" in Walker Hemi Turbo mufflers connected to Corvette cast iron manifolds. The Butt-o-Meter suggests it equals the power output of the Heddmans and 2 1/4" exhaust it replaced. I'm planning on same exhaust setup for my 69 short step when I swap in the 427 but am running the very expensive Sanderson iron manifolds. Engine Masters did a 2 1/2" versus 3" exhaust system and it's not worth it unless you are north of 600 whp. 2 1/2" was cheaper, easier to route, quieter and made equal power.
02-05-2018, 10:08 PM | #13 |
My 292 runs a dual 2-1/4" with Magnaflows and an H pipe. I can barely hear it idle but it's got one hell of a getting when I mat it. I do have a drone at 55mph but I don't have a floor mat either.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
02-05-2018, 11:56 PM | #14 |
Single factory exhaust is purely a matter of economics. Two cylinder heads/two exhaust manifolds means two pipes for me. I'm 62 and will never outgrow that . It's the first thing on my list, usually.
