Disc brake conversion
What does it take to convert a 68 chevy to disc brakes in the front? Will I need a brake booster?
Newbie Posting ![]() ![]() |
student wrench turner
there are a lot of vendors that sell a complete kit
1969 Chevy C-10 with 250 L6 2002 GMC Sierra 2500 HD Duramax with banks six gun |
skokie, where are you from????
67 3/4 4x4 402,a/t,flat bed 98 GMC Sierra swb daily driver 87 burb parting out. 68 1/2 chevy, 350/350, 71 gmc frame, kid's beater 69 1ton 396-4sp, dump 69 swb stepside 396/400th current frameup 67 swb 454/400th rebuilding now, oldest boy just rolled it 99,HD, Road King Classic Colwich Ks |
San Jose Ca. Not Illnois.
If you have the motor out, swap in a complete frontend off of a 71-72. Easy, bolt right up. Otherwise check with some of the vendors like rustyold69 said, Greg
Yes, you'll need a power brake booster, or at least a master cylinder from a truck with disk brakes.
I'm adding front discs by swapping in a front crossmember from an '84 chevy 1/2 ton. It's amazing how little these trucks changed over the years, because the '84 cross member is almost identical to the one from my '68. You'll need to drill two holes (at least I did), but otherwise the thing is bolt-in. If you have the cash to buy a new kit, good for you. But this plan is pretty economical as there are tons of these old trucks at the wreckers. The parts are inexpensive and available everywhere and the swap is pretty easy to do. I haven't solved the master cylinder problem yet. Does anyone have a suggestion? I can't find a power booster/master cylinder from a '69-'72 truck to swap in. Will other years work without too much difficulty?
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
Get the spindles, brake booster, master cylinder, and proportioning valve from a 71/72. You can probably find the whole set up for under $150.
69 SWB LT1/4L60E www.classicplace.com |
Resident Young Old Dude !
I bought the complete changeover kit, from Tuckers in Las Vegas.
It cost I think $699.00 ( or something in that area) I got the dropped spindles,calipers, rotors,dropped springs,all disc hardware, lines etc. The only thing it didn't have ( and junkyardjohn found me one) was a proportioning valve. Yes I could've went the junkyard route, but Why start with used and have to change again sometime in the future.. Ron |
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
blue c/10 just get a new master cylinder and brake booster its not worth taking the chance with 30 year old parts that will probably fail in short order anyways or have already failed. same goes for the prop valve. the brakes are the most important thing on a truck if ya cant stop it things get real scary. i feel my life is worth 200 bucks in new parts to know they will work properly
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
all you need is the spindles out. you`ll also need the master cylinder and proportioning valve. i just bought a set for my `68 off of a `71 and was told i`ll need the `71up ball joints,tierods,centerlink,ect. there is many ways to do the swap, just depends on how you want to do it.
Anthony |
Grab some of the other parts too...The booster core value is $60 at the parts store. The master cylinder has a core value too. I replaced all the wear items, but used all the used parts for their core values.
#13 |
Keepin an eye out
Ive been doing the used parts/ junk yard route. If I had it to do over I think I would just spend the money and get a kit. I have gathered alot of info though. Brake lines will be my next hurdle.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#14 |
Life is Good !
I am looking into a 73 and up swap ! I know a guy who has a short bed 73 that is just sitting and I was thinking about getting the parts off of it to swap the drums out of our 69 burb ! Will this work ?
If it will not I will have these parts for sale ! Landon
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
#15 |
this is what i put on
David M Proud Owner of A 67 C10 Shortfleet 350/350/3.73 |
#16 |
Thanks for answering my questions about the master cylinder/booster.
I'm also wondering about the pedals. I've got a truck that came with a 3 on the tree and I want to go to an automatic. Do I need to go with 67-73 automatic transmission pedals or can something newer fit? Is it a big deal to change the pedal assembly? Does anyone have a shoe horne big enough to fit me under the dash?
#17 |
I cant speak to the pedals but I can speak to the column swapout. Make sure you have all of the washers.
#18 |
The automatics use the same brake pedal as the standards do. Just pull the clutch pedal and you're done.
#19 | |
Originally I was just going for those since I had a booster but sounds like you've had some experiance, unpleasant at that.
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
#20 |
Keepin an eye out
You need the same year master/booster as the brakes your using. If using 71-72 brakes use a 71-72 mas/booster. Also make sure if you have a c10 to use c10 master/booster.
