Old 02-05-2018, 03:18 PM   #1
72Ken
Question about gas tank/sending unit replacement
Hello all. Newbie here and needing some help. I tried searching some old threads but didn't have much luck finding out what I needed, forgive me if this has been explained already. Purchased a 72 C10 years ago and shoved it in my barn. Finally getting around to tinkering on it. Truck appears to be all original with 307 2bbl and Auto trans. Ordered a new gas tank--matched up that mine has EEC, and ordered new sending unit--matched up that I need the "72 with auto trans". I install new tank and notice there is an extra hole punched in the top for a bolt (no problem). But also notice that there is not a threaded hole for the fuel line to secure to (see pics). Also the old sending unit only has one line and the new unit has 2 lines. Like I said everything seems to be original but I could be wrong. Anybody ever come across this before? Im sending the new unit back to get the "manual trans" with single line.
72Ken is offline   Reply With Quote
Old 02-05-2018, 07:01 PM   #2
Gromit
Re: Question about gas tank/sending unit replacement
I have the 1970 with the EEC not the 1972; so please take the two year difference into account; but my tank also has just one connection at the sender.
That threaded hole you mention looks as if it was drilled into the tank itself - I mean perforating into the same space where the gas goes!
Mine doesn't have that either and I'll be surprised if that is factory.
I'm sure you know this but just a reminder when you have that sender off; beware of static electricity or other sparks near the opening.
Photo attached of 1970 tank with EEC
Gromit is offline   Reply With Quote
