Old 02-05-2018, 03:22 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
67-72 cargo light switch
I am installing a cargo light on my 68' 4wd shortbox I am building and Cant bring myself to install the old nasty switch. Is there a replacement for these?
I am still in the bodywork phase and will be painting soon. I can weld the factory hole up if there is another option? I just dont want to do a cheap toggle switch on the dash, so If someone has a clean way/idea to install a different switch I am all ears.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 02-05-2018, 04:58 PM   #2
HO455
Post Whore
HO455's Avatar
Re: 67-72 cargo light switch
This is what I bought.
https://www.classicindustries.com/pr...ts/cx1792.html
RIP Bob Parks.
Old 02-05-2018, 05:22 PM   #3
bigbadchev72
People know me
Thank you, that is what I was looking for!
Old 02-05-2018, 10:04 PM   #4
HO455
Post Whore
HO455's Avatar
You are welcome, glad I could help.
RIP Bob Parks.
Old 02-05-2018, 10:37 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
Am I missing something? My cargo switch is back by the interior dome light. That switch says it mounts to the dash.
Tyler
57taskforce is offline   Reply With Quote
Old 02-05-2018, 11:16 PM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
That's where they are usually mounted, below the dome light above the rear window.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-06-2018, 07:32 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: 67-72 cargo light switch
This switch goes under the light inside the cab for the cargo light.
Here is mine. Not a good picture but it's in the correct spot.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
