Old 02-05-2018, 07:08 PM   #1
Chevystep
Window beltline fuzzy solution?
Put in the standard anti rattle strips and like most here, run into a problem with the strips being so fat (not judging, they’re just wide!) that the window has a problem with running all the way up into the top door frame weatherstrip. SO...used the standard anti rattle on the inside with the frustrating clips and then found a squeegee like strip for the outside that is considerably thinner (Steele Rubber outer beltline weatherstrip -70-3807-61. It has a metal core so I marked the clip holes in the door on it and drilled holes through it to fasten it to the door with.........nylon bolts, like a 10-32, so as not to scratch the glass. Picts of what I used below. Forefinger is on the felt/rubber squeegee part that rides against the outside of the window. Would have like to have found black nylon but it’s in the door. Window goes all the way up and seats, and kind of squeegees on the way up and down like a modern car. Time will tell if they last. Installation tip?...put the glass in the door and let it fall to the bottom, easier to push it up through the installed weatherstrip with just the glass going thru rather than pushing the bottom frame through the fuzzies like the manual would have you do. You can still get it in the regulator channels without the vent window installed.
Chevystep is offline   Reply With Quote
Old 02-06-2018, 03:22 AM   #2
yeah_yeah_na
Re: Window beltline fuzzy solution?
Nice work, what is the original use of those nylon bolts? They look handy for more than just this job.
yeah_yeah_na is offline   Reply With Quote
Old 02-06-2018, 09:19 AM   #3
Chevystep
I think you see them a lot in computers, at least that’s what came up when I looked online. But most good hardware stores have some in their bins.
Old 02-06-2018, 10:15 AM   #4
nsb29
nsb29's Avatar
Where did you get the squeegee type outer Seal
nsb29 is offline   Reply With Quote
Old 02-07-2018, 09:23 PM   #5
Chevystep
Steele rubber
Old 01-02-2019, 03:41 PM   #6
Chevystep
Picture of the Steele outer weatherstrip piece in the door with the plastic nut....
Old 01-02-2019, 04:06 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Interesting. I wonder if they make them with a slight bend at the end?
Old 01-04-2019, 05:16 PM   #8
jbgroby
jbgroby's Avatar
following
jbgroby is offline   Reply With Quote
Old 03-02-2019, 07:08 PM   #9
norcalcap
I installed some outers after reading this post. Got a set from Steele. As far as I know, they only come straight, no bend at end. I followed the bend of my new inner felt and made some relief cuts on the lower edge to create a bend. Im sure leaving them straight or adding a bend has no effect on intended use but I like the look of the bend to kinda match OE. I attached with plastic hardware like the OP did. Plastic hardware seams to have a slightly smaller head which reduced the chances of it rubbing on the lower channel when glass is all the way up. Very happy with the outcome.
norcalcap is offline   Reply With Quote
