02-05-2018, 10:29 PM | #1 |
New truck 79 K20
Got a new truck to work on. Really like it. Steering is loose. That’s the first order of business. Any good threads on this please share! Not sure if I just just rebuild it all or try to diagnose. Parts are fairly cheap... tried to post pics but no dice. Wouldn’t open up to add attachments. I’ll learn lol
02-05-2018, 10:30 PM | #2 |
Re: New truck 79 K20
Maybe the pics did work...
02-05-2018, 10:35 PM | #3 |
Couple details
K20 350 (rebuilt about 10k ago) TH400 trans NP205 transfer case. 14 bolt FF corporate rear end 12 bolt corporate in the front. 4” Rough Country Suspension Lift |
02-05-2018, 11:00 PM | #4 |
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
02-05-2018, 11:03 PM | #5 |
Thanks, I registered for a few other sites and they never responded to me. Found this one and I can finally start learning about my new wheels. Pretty excited to be here!!
02-05-2018, 11:14 PM | #6 |
Welcome nice looking truck! The loose steering can be caused by a couple different things. Gearbox, tie rods, ball joints, ect. When I got my 78 it had loose steering as well. I checked it out and it ended up being the drag links. I replaced them and now it steers great. So I recommend checking yours out.
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
02-05-2018, 11:19 PM | #7 | |
02-06-2018, 06:39 AM | #8 |
The poor truck is begging for 33's. Welcome, there is lots of info in here.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-06-2018, 08:46 AM | #9 |
I may have to get a new set of rims . From what I gather these are 16x7’s. Maybe 7.5’s. I think most 33’s are going to require 16x8 or larger aren’t they? I do want a bigger tire though. I think it will certainly add something to the truck!
02-06-2018, 10:43 AM | #10 |
Active Member
Welcome to the site! Great looking truck, definitely need some bigger rubber on there.
02-06-2018, 01:09 PM | #11 |
I’ve read it’s doable but does anyone recommend a 285 75 16 on a 16x7?
02-06-2018, 01:11 PM | #12 |
Right now it’s a 245 75R 16
02-07-2018, 11:48 AM | #13 |
Moderator
I run 285 75 16s on both my 1976 K20 and my 2000 T400 C20... That's almost 33" tread diameter. They fit the stock ride height T400 C20 with no rubbing but the squares are not quite the same truck... My K20 is lifted similar to yours so they'll fit just fine.
The 285 tires fill the wheel wells and look "right"... they don't look like someone put rubber bands around a Cheerio and slapped em on a Hot-Wheels truck like the 245 tires do. A lifted truck is going to wear the ball joints and linkage joints faster than a stock ride-height truck. They can also stress the frame where the steering box mounts. You want to take a look at the frame where the steering box mounts. ORD sells repair/reinforcement plates and braces to keep the box from stressing the frame as much. I'd install em even if you don't have cracks yet. The rag joints feel loose when the steering box, frame, linkage, etc are just fine. Google K5 XJ steering shaft. Chrysler/AMC used Saginaw steering columns and boxes in the Jeeps. You'll find forum posts and YouTube videos on installing the Jeep u-joint steering shaft in the CK squares.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-07-2018 at 12:11 PM. |
02-07-2018, 01:30 PM | #14 |
The truck is a 1979. I believe it’s a Silverado from the interior and power options. Not entirely sure. I have to run the vin and do some investigation on that.
02-07-2018, 01:35 PM | #15 |
If it has a tilt column, there are 3 screws at the bottom of the inside that will cause slop if loose. PITA to get to as you have to pull all of the column guts.
02-07-2018, 02:45 PM | #16 | |
02-07-2018, 02:46 PM | #17 |
02-07-2018, 08:19 PM | #18 |
I took a look at ORD and checked out those brackets. Looks simple enough. I’m going to do the steering shaft swap. I can get a discount on parts through work so I’m waiting on information before I buy anything. Anyone in Northeast Wisconsin that needs parts I may be able to get a discount. I’ll post if it’s worth while or not
02-07-2018, 10:32 PM | #19 |
Took a closer look and I found it’s got a 600 Holley dbl pumper on it
02-09-2018, 01:40 AM | #20 | |
02-09-2018, 09:00 AM | #21 |
fyi the rough country lift is the stiffest off the shelf lift kit . and the cheepest .
also your truck is worth gold if it has a 12 bolt front end . there is 10 bolt or dana 44 or dana 60 . never a 12 bolt front . good luck on the fixer up list and keep us posted.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
02-10-2018, 03:59 AM | #22 |
Needs some MUDDERS
03-12-2018, 07:01 AM | #23 |
Truck has expensive taste l... begged forc35’d
03-12-2018, 11:13 AM | #24 |
Man, that wheel / tire combo make it look like a new truck!
I might recommend getting some body gap fillers put in behind the wheel, would frame your wheel/tires much better. It's basically a piece of sheet metal painted black that sits behind the upper tire and hides the frame parts. LMC Part 30-2440. I'd also get an air deflector if yours is missing in the front under the bumper. LMC Page 39. These (2) pieces sort of bring your cab down to the tires a bit visually. But that's just a personal preference. |
03-12-2018, 12:03 PM | #25 |
Made a huge difference
