Old 02-06-2018, 10:15 AM   #1
Wantavant
Help on Rally wheel size?
I just picked up an 86 C-10 rcsb and was wondering if the wheels are 15x7 or 15x8? Are there any special markings I can look for, the tire size that came on the truck are 235/70 15......thanks
Wantavant is offline   Reply With Quote
Old 02-06-2018, 10:16 AM   #2
Jaysonb
Jaysonb's Avatar
Re: Help on Rally wheel size?
Truck rallys are 8".
Jaysonb is offline   Reply With Quote
Old 02-06-2018, 10:19 AM   #3
Wantavant
oh, well thats perfect! Thank you for the help!
Old 02-06-2018, 10:39 AM   #4
SCOTI
SCOTI's Avatar
It's a used 1986 truck. Just because it might of came w/8" truck ralleys doesn't mean it still has them. People are known to change things around. Post up a pic of the wheels to get a definitive answer.
There are also the less common 7" ralleys as well as 6.5's from vans. Then there are aftermarket sizes too....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-06-2018, 10:51 AM   #5
My daughters's 82 came with 7" ralleys from the factory. As mentioned, trucks could be 7 or 8 inch wide, depending on how it was ordered. Van's had the 6.5" ralleys. This is all for the 5 lug ralleys. Far as I know the 4wd (6 lug) ralleys only came in 8 inch wide. As mentioned aftermarket lets you get a few more widths and diameters that what came from the factory. From what I have seen, the non-silverado models tended to have the 7" ralleys. That's just my experience. AS mentioned, who the heck knows if those are original to the truck or not.
Old 02-06-2018, 11:00 AM   #6
Wantavant
Here's a few pics, can you tell from these what size they are? Don't mind the ugly bed cover....lol
https://www.flickr.com/photos/159340...posted-public/
Old 02-06-2018, 11:04 AM   #7
I would say those are 8" from the depth of the trim ring.
This is what the 7" ones looked like.
Old 02-06-2018, 11:10 AM   #8
Wantavant
Ok thank you guys! Gonna be dropping the truck soon and wanted to make sure I could fit a 275/60 tire on the rear.
Old 02-06-2018, 12:33 PM   #9
SCOTI
SCOTI's Avatar
To be sure, you can always take a wheel off & measure. Measure from the mounting pad to the back edge & then again to the front edge. Add the dimensions together & subtract 1" (~.500" for each bead).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-06-2018, 12:36 PM   #10
Wantavant
I was looking all over the wheels last night, i did see an 8 stamped on the outside by the valve stem but not sure if that has anything to do with it.
