02-06-2018, 02:36 PM | #1 |
Zinc additives , Here's a sale for you
Shell X-100 classic oil and zinc additive are on clearance at Autozone , They normally run $18-$20 each now at Autozone $3.97 in store only
https://www.shellx100oil.com/classic...oils-additives |
02-07-2018, 10:00 AM | #2 |
Re: Zinc additives , Here's a sale for you
Good tip, Grump! Going there after work...
02-07-2018, 10:51 AM | #3 |
Yeah , I like the metal cans and seen them sell on ebay for $20.00 empty .
02-13-2018, 08:07 PM | #4 |
Managed to score 4 cans at $0.97 each here in NJ today. (2each at 2 stores).
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
02-13-2018, 09:45 PM | #5 |
I’ve been searching down here for a can, nobody carries it.
I wanted one for my Shell collection, yes I work for Shell and can’t get one. Lol. Ironic isn’t it. Anyone wanna sell me one?
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
02-14-2018, 02:42 AM | #6 |
Thanks for the heads up, Grumpy.
I bought 2 quarts of Oil Stabilizer at .97 cents each at my local A/Z. They were out of the zinc additive, but the store guy called around for me. No luck, though. So what do I use oil stabilizer for anyway? He also said Rotella SAE 30 still had the right amount of ZDDP. I said I didn't know Rotella came in straight weights, I thought it was all 15W-40 but there was a couple gallon jugs of 30 weight on his shelf. So is it true that Rotella straight weight oil still has sufficient amounts of ZDDP for our pre-catalytic/hydraulic cam purposes?
02-14-2018, 07:41 PM | #7 |
Thanks Grumpy!!!
I went in for the zink but a huge number of items were $.97 Heres my haul from 5 stores, only took what I could use,much more left! |
02-14-2018, 08:42 PM | #8 |
Looks like you scored You probably saved a couple hundred just on the Shell additives ? I always check the clearance for the deals I'm going back to see if the gear oil is on clearance here .
02-14-2018, 08:48 PM | #9 |
02-14-2018, 08:49 PM | #10 |
Grumpy, thats not gear oil, its oil stabilizer(black bottles). Only the "additive" section had clearance. I did score 150 quarts of oil two years ago for $1/quart when they closed out some items at end of year.
02-14-2018, 09:35 PM | #11 |
Thanks a grumpy. I PMed the info to you.
I appreciate it.
02-15-2018, 03:48 PM | #12 |
Thanks for the heads up Grumpy. Went to both stores here in Blount county,only had one can. This is what I like about this forum,members helping others.
'71 Cheyenne Super LWB - Second Owner in 39 Years! '70 CST/10 SWB - Soon to be Daughter's truck when finished |
02-15-2018, 04:25 PM | #13 |
nano gear lube 75w-90 synthertic is 5.00/qt
02-15-2018, 09:34 PM | #14 |
Whoop whoop, I found 2 cans at an autozone in another town I was in today. Sweet.
