Old 02-06-2018, 07:58 PM   #1
stanski
Drop Shackles Longer or Shorter?
Is a 2" drop shackle longer or shorter than the original?
stanski is offline   Reply With Quote
Old 02-06-2018, 08:21 PM   #2
TrailerTrash
TrailerTrash's Avatar
Re: Drop Shackles Longer or Shorter?
Longer. You will need to notch out the bed supports directly above the shackle
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 02-06-2018, 09:17 PM   #3
stanski
Thanks. And good news is there are no bed supports on a Jimmy.
Old 02-06-2018, 09:28 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Not always.
These trucks came with two different length leaf springs.
Some were 52”.
Others were 56”.
If you have the longer springs (8 leafs usually, 56" overall length) you will NOT have to notch the crossmember. If you have the shorter light duty springs (52"), you will have to.
Keith
Convert to disc brakes.
Old 02-06-2018, 10:59 PM   #5
sweetk30
sweetk30's Avatar
i notched mine with half a chunk of exhaust pipe . few pics of the job .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-06-2018, 11:01 PM   #6
sweetk30
sweetk30's Avatar
and added drain hole on other side to match other side
Old 02-06-2018, 11:48 PM   #7
Redneck Rydes
Redneck Rydes's Avatar
Good idea and looks great!
Redneck Rydes is offline   Reply With Quote
Old 02-07-2018, 09:43 AM   #8
sweetk30
sweetk30's Avatar
kept it the least amount removed required . but with the arch it gets me the room for shackle swing i needed .
