points wiring
anyone have a diagram on how to change from HEI to points for a straight six?
i am swapping engines between 2 trucks and i dont want to spend the money on HEI to just sell the truck. |
![]() Join Date: Jan 2011
Re: points wiring
Just install the engine and hook the wire that used to supply the power to the hei to the coil if it does not use and external resister or to a ballast resistor if it needs one. Thats it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Re: points wiring
^ Ditto.
Some coils are printed with a message such as: "Use with external resistor". But if that is missing, worn off, or you just aren't sure, you can use a multimeter (set to the resistance / Ohms scale) to measure the coil's primary resistance. Just hook the meter's leads to the coil's (+) and (-) terminals without any other wiring attached. A stock GM Delco coil (or equivalent replacement) will most likely read somewhere around 1.8Ω and require an external ballast resistor. But some coils have a higher primary resistance (around 3Ω or so) and can be used without an external resistor. The factory wiring (in most cases) also incorporated a wire that would temporarily bypass the ballast resistor to feed full battery voltage to the coil for a hotter spark while cranking the engine. That can be duplicated by simply running a wire from the starter solenoid "R" terminal to the positive coil terminal. |
