02-07-2018, 03:50 AM | #1 |
Parasitic Draw
Hello all! My new battery keeps dying after about 3 days in my 85 k20. I've tested the draw, and I get about 0.180A. I started pulling fuses and found the Horn/dome fuse to be my draw. My horn works normally, and the dome light is completely disconnected.
I'm fairly good at electrical but this one is really getting me. Does anything else run off that fuse? I have an aftermarket radio and tach but those don't seem to be the issue. Appreciate any help!
Rich My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case. |
02-07-2018, 07:23 AM | #2 |
Re: Parasitic Draw
You said your dome light is disconnected? Is it disconnected at the light bulb or the door switches? The action of the dome light starts at the door switches or light switch, and ends at the bulb. Try that, then go to the horn? Pull that fuse for a few days and see if it still kills the battery. Then you know where to go from there.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
02-07-2018, 08:08 AM | #3 |
Re: Parasitic Draw
I think what I would do is unplug the relay for the horn and see if the draw stops . If not look to the dome circuit . I think those 2 things only share power source . This may give you a direction to go .
02-07-2018, 11:20 AM | #4 |
Re: Parasitic Draw
Door switches are disconnected, as well as the harness connector behind the seat for the dome light. I unplugged the horn relay also, no draw change.
02-07-2018, 11:44 AM | #5 |
Moderator
Re: Parasitic Draw
There are three rows of accessory plug-in connections across the top of the 1985 fuse block where various optional sub-harnesses were plugged in by GM--(Factory/Dealership) or previous owners. The GM systems will have obsolete keyed connectors to keep you from plugging the harness into the wrong slot.
According to the 1985 wiring diagrams the DOME/Courtesy-Floor-Lamp is the ORANGE wire in the Lower Left accessory plug-in position on the 1985 fuse panel. Un-plug it and see if your parasitic draw disappears. Circuit 140 also powers the HAZARD lamps...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
02-07-2018, 12:07 PM | #6 |
Re: Parasitic Draw
This trucks wiring has been messed with a lot before I got a hold of it. I followed the dome lamp wiring up to the fuse block and I see a connector with an orange wire plugged in to the upper left. Disconnected it, no change in draw.
02-07-2018, 12:14 PM | #7 |
Moderator
Re: Parasitic Draw
That likely rules out your dome lamp wiring.
The Horn relay makes no difference too. Since the Hazards are on Circuit 140 too I'd pull the flasher relays and see what difference that makes... I've read about some electronic flasher relays causing a parasitic draw.
02-07-2018, 01:32 PM | #8 |
Re: Parasitic Draw
A lot of aftermarket radios have a memory wire that the install manual will say to connect to an always hot source.
Does your truck have one of those under hood service lights? Don't remember when they started putting those in, just remember seeing some at the pull-a-part and getting one. Any chance a PO installed some kind of LowJac device? Would likely be hidden and connected to an always on source. |
02-08-2018, 12:45 AM | #9 |
Re: Parasitic Draw
Unplug your alternator & try that. If it has been sitting a while it can get that white corrosive powder in it that will conduct when damp.
02-08-2018, 04:34 AM | #10 |
Re: Parasitic Draw
Thanks for all your help! Found the source of my draw. My aftermarket tach was plugged in to one of the "B" terminals on the fuse block. Dug up the diagram for the rear of the fuse block (note the image is reversed because you're viewing the fuse block from behind) and you can see where the B terminals are on the same circuit as the Horn Dome fuse.
I have .001A draw now. Perfectly within reason. Moved the tach battery positive lead to a switched ignition terminal on the fuse block. Hope these images can help someone else too. Thanks again!
02-08-2018, 10:43 AM | #11 |
Re: Parasitic Draw
OK then it was "On" all the time.
