Old 02-07-2018, 11:21 AM   #1
rockyrivermark
Rear end swap
1970 c10
350 cu
350 auto
Truck currently has 12 bolt non posi rear end.
Was converted to 5 lug by PO
Got a chance to pick up. 10 bolt 8.5" posi from a '72. Has axles but missing drums.
Should be a direct swap right for both rear end and used my old drums?
Anyone done this have any info or tips.
Mark
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 02-07-2018, 11:26 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Rear end swap
1972? A 10 bolt would have come out of a car, right?
Sorry but I don't know the answer. While GM was pretty good at interchangeability but I don't know about this application.
GM did switch to 10 bolt axles in trucks sometime around 1980. It was considered a downgrade in strength.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-07-2018, 08:47 PM   #3
Mike C
Mike C's Avatar
Re: Rear end swap
Realistically, the 8.5" 10 bolt and the 12 bolt are equal in strength. Certainly by the late 80's when they went to equal size 30 spline axles.
But to BigDav's point, they weren't found in trucks until the '79-'81 era and they were still using 12 bolts in some models.
It would better serve you to just add an LSD to your existing 12 bolt IMO.
The 8.5" posi from a passenger car was an excellent unit, but trucks always got the Gov-Bomb so make sure you know what you are getting. Big cars were same bolt pattern as truck, but Camaro/Chevelle/Nova was smaller.
Caveat Emptor...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-07-2018, 09:03 PM   #4
rockyrivermark
Re: Rear end swap
Thanks for the info. The seller send me a pic and I noticed it didn't have a hole for the track bar. I'll be passing on it and I'll install an Eaton posi into my exsisting 12 bolt.
Thanks again
Mark
My build page
Old 02-07-2018, 09:50 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rear end swap
A stock "10 bolt" out of a 1972 will be an Eaton or a Dana... both 8 luggers. It doesn't have a track bar because it is probably leaf sprung.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
