Old 02-07-2018, 02:17 PM   #1
upon1
upon1's Avatar
Brake lines from master cylinder
For those of you that have redone your brake lines using a firewall mount master cylinder, did you put the coils in the line like most factory lines have or a nice clean bend in them. I know it’s for viberation but lots of people seem to leave that out.
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 02-07-2018, 03:42 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Brake lines from master cylinder
" lots of people " may have a leak someday to....it need some flex in it...not necessarily between the master and firewall like in your pic...no movement there......it needs to be between master and frame...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-08-2018, 05:48 PM   #3
youngrodder
youngrodder's Avatar
I did not make a coil with mine. I liked the cleaner look without the coils. They have worked fine for years...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-08-2018, 08:32 PM   #4
oldman3
oldman3's Avatar
I also did not put a coil in mine. Have worked fine for the last 10 years, not leakes...Jim
oldman3 is offline   Reply With Quote
Old 02-09-2018, 01:15 AM   #5
dsraven
try to leave a slight slope in the lines back to the master so any air in the system can find it's way out. not a big deal but makes bleeding easier. if you do a system like old man did there is enough line there to take up any required "movement" between body and frame, and it looks real clean and professional. if you decide to do a small coil also ensure to make it easy for air to escape through the master.
Old 02-09-2018, 03:50 AM   #6
Jesse Z
25 years of building cars, never put coils in MC lines, never had a leak.
Jesse Z is offline   Reply With Quote
Old 02-09-2018, 08:37 AM   #7
1project2many
The cab mounts on the old trucks do not allow as much movement as on newer vehicles.
I would probably include the coils below the toe board of the cab.
1project2many is offline   Reply With Quote
Old 02-09-2018, 03:51 PM   #8
Krustyone
If you're concerned about body to frame flex, you could always put a quality short braided line at the junction and have clean lines to the MC.
Krustyone is offline   Reply With Quote
Old 02-11-2018, 12:39 AM   #9
upon1
upon1's Avatar
Thanks for the replies. I went the similar route that oldman did. I liked the clean look of it better and there is still some movement allowed with the angles.
Project 55 To Life
Old 02-11-2018, 12:00 PM   #10
Black_Sheep
Black_Sheep's Avatar
Yep, the front cab mount is a 1/16" piece of rubber so it's essentially solid.
Black_Sheep is offline   Reply With Quote
Old 02-11-2018, 10:05 PM   #11
my56chevytruck
my56chevytruck's Avatar
I don't have a picture of my lines, but I did at first have a loop, only because the "experienced" people said to do so, but I liked the clean look so I removed those lines and put in the new ones i have now. NO loops, but I do have a mild bend in them. My .02 worth
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
