Old 02-07-2018, 11:00 PM   #1
Worldofhurts
Rear end leaks
Hey guys I have a question about the rear end of my 67 C10. I sandblasted it about a week ago and was just getting around to it. It has been sitting on jack stands this whole time and I noticed some oils seeping on the bare metalbut no drips. (See the attached photos). Is this normal? If not what are some ideas for repairing it. Thank You
Worldofhurts is offline   Reply With Quote
Old 02-07-2018, 11:16 PM   #2
Wrenchbender Ret
Re: Rear end leaks
I don't see any photos.
George
Wrenchbender Ret is offline   Reply With Quote
Old 02-07-2018, 11:22 PM   #3
Worldofhurts
Re: Rear end leaks
Sorry I hope they uploaded .
Old 02-08-2018, 02:54 AM   #4
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Rear end leaks
I feel every think has a little sepige.The tubes are pressed in it dose happen.If your worried put some cocking on the tubes.its a truck.Its not a Super Bird
stsalvage is offline   Reply With Quote
Old 02-08-2018, 09:36 AM   #5
sick472
sick472's Avatar
Re: Rear end leaks
Your wet spots by the welds may be seepage, that could very well be. Same at the tubes, but they might just be oils coming back out of the joints/porosity that seeped "in" from the outside at some point and is now working back out. Either way, it's not much to worry about. Make sure you spray down with brake parts cleaner right before you prime and paint so that the paint sticks. Heck, the paint may be enough to seal it up.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-08-2018, 11:38 AM   #6
Bigdav160
Bigdav160's Avatar
Re: Rear end leaks
The tubes are pressed in and plug welded. Seepage there is pretty common. On my Dana 44 it's more of a drip
Many people will weld completely around the tube to prevent it from getting loose and to prevent the leakage.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
