02-08-2018, 09:49 PM | #1 |
Cupped lower A arms
I’ve searched and searched and only found one company that made them at one point but since has stopped. I’m looking for some cupped lower a arms for a 63-66 C10. Does anyone make them or does anyone know where I can send mine to have them done?
Any tips or suggestions would be great! Posted via Mobile Device |
02-09-2018, 09:12 AM | #2 |
Re: Cupped lower A arms
If you have some one close that can do the welding I have a set of the way2lo cups that I bought for a project and never used.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-09-2018, 09:50 AM | #3 |
02-09-2018, 01:53 PM | #4 |
There is a guy on facebook who does them called Squared Away Customs if I remember correctly.
Its super easy to do. You can cut them in yourself and any shop should be able to weld them in. Im sure even a muffler shop could do it. I got my cups from Speedy Metals. They cost a few bucks more but will cut them to whatever size you want. Saves some time and hassle.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-09-2018, 04:37 PM | #5 | |
02-09-2018, 06:12 PM | #6 |
You could also just plate them.....
02-09-2018, 06:15 PM | #7 |
I did a pair for my dually a little different but the same idea.....
02-09-2018, 08:14 PM | #8 |
I'll go and get a large flat rate box and see if they will fit and let you know. Give me a zip code.
Jimmy
02-09-2018, 08:33 PM | #9 |
02-10-2018, 08:26 AM | #10 | |
I got a set of cups from way2lo (Boris) instead. I tried pricing them out locally but honestly I couldnt find anyone that would beat his price unless I bought a large piece and then I had no idea how I was going to get it cut into the 2" lengths.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
02-11-2018, 10:28 AM | #11 |
PM inbound.
Jimmy
