02-11-2018, 10:40 AM | #1 |
Wheel tub bolt?
Not sure why the rounded head bolts are at the top of the wheel tubs on my 66, but I was planning to weld up the hole and smooth it out. Anyone know why they might be there?
02-11-2018, 10:47 AM | #2 |
Post Whore
Re: Wheel tub bolt?
I've got a new set...no bolt or hole there...
02-11-2018, 11:40 AM | #3 |
It's Better With Nitro
Re: Wheel tub bolt?
The only thing I can think of is that a previous owner had some type of rack or bed divider mounted to the wheel tub(s). There shouldn't be any fasteners in that area - I would also remove and weld up the hole.
02-11-2018, 12:53 PM | #4 | |
1965 Chevy C10, 2005 4.8L/4l60
Re: Wheel tub bolt?
Ditto!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-11-2018, 04:01 PM | #5 |
Re: Wheel tub bolt?
Thanks guys! I know they had rails cause I had to weld those up too. The inner edge I had some holes that were not fun to smooth out. Couldnt swing a hammer in there so I rigged up a method and used the slide hammer.The tubs shouldnt be too bad. Gonna go out there now and start.
02-11-2018, 08:22 PM | #6 |
Re: Wheel tub bolt?
Oh, wow! Yeah, there you go. I've seen a few bed racks and dividers in my day mounted in all sorts of ways...unfortunately, almost always to the wheel tubs.
