02-11-2018, 04:44 PM | #1 |
Rear flip kit 77 big10
I started installing the rear flip kit on my 77 c10 big 10. I did some measurements and it looks like the axle will be within an inch of the frame after the flip is done. I did the flip on my 82 c1500 a few weeks ago and after the flip there is about 3 inches of clearance. I didn't notch the frame on the 82. I wasn't planning on notching the frame on the 77 but there is no way I could flip it and not.
I know the big 10 springs have more leafs but is the spring a flatter spring? I'm guessing the frames are the same. I made my measurement assuming the rubber bumper and bracket are removed
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
02-11-2018, 10:26 PM | #2 |
Re: Rear flip kit 77 big10
Big Ten (Heavy Half) has more leafs, and it is a 56" spring vs a 52" I believe. I had put new leaf springs in my Dads build and ended up, after the flip, about where you are now, maybe a tad more room. Your springs are more than likely original and have lost a bit of there strength????? IDK, taking a stab at it.
Thanks Mike
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
02-12-2018, 08:38 AM | #3 |
We have flipped a couple of squarebody rear axles and most all of them are fine with no c notch. I just flipped my 77 c10 and it has more springs then all the other trucks Ive done, idk if that affects it but mine is probably gonna have to be c notched. Mine had one more leaf then the other 3 Ive done in the past. I didnt wanna notch mine either..
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
02-12-2018, 09:20 AM | #4 |
Mine is a Heavy Half and I didn't need to notch it when it was flipped. It was close but the only time it hit was when I had about 7-800 lbs of scrap metal I was hauling off. Normal unloaded driving was fine and it never bottomed out then.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
02-13-2018, 10:48 AM | #5 |
The quantity of springs directly affects the amount of drop.
HD spring packs (8-leafs) will yield more drop vs. standard/Lt. duty set-ups (4-5 leafs).
02-13-2018, 03:41 PM | #6 | |
Just my two cents.
02-13-2018, 03:43 PM | #7 |
Also, you don't already have drop hanger/shackles do you (4" drop)? That too could be your problem. I went back to OE hanger and shackle when I flipped mine. Thanks Mike
02-13-2018, 05:56 PM | #8 | |
My statement is about using the spring pack that's already under the truck so there is no change. The only thing that changes the height/dimensions are the lowering parts (flip kit or shackles/hangers). My bet is most folks just swap the parts & don't do new leafs @ the same time.
04-15-2018, 01:11 AM | #9 |
I’m having the same problem with my 78 Big Ten. I got it free a couple wheels ago and I got the flip kit as a gift from a friend who’s truck it wouldn’t fit. The axle will just about sit on the frame if I flip it now. But would it be easier to get a pair of standard duty leafs from like a scrap yard and then do the flip? I can post pictures later.
1990 350 Suburban 1978 350 Big Ten street truck |
04-15-2018, 11:06 PM | #10 |
When I did my 4 / 6 drop my rear springs sagged bad - I had them re-arched and put them back in and it still sagged. So I had them add another leaf in and arch again and it came up to the proper height. I wouldn't bother going the junkyard route as you could end up with worn out leafs. Having to redo it was a pain in the ass so just trying to help you save some headaches.
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
04-16-2018, 06:53 AM | #11 |
http://www.sdtrucksprings.com/
new is the best route . dont waste your time with re-arching and then other stuff . i have purchased from these guys before with good results.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-16-2018, 06:43 PM | #12 |
I ended up flipping mine using the stock springs. I figured if it the axle hit the frame I would notch it or try to raise it with some shorter shackles (not sure these exist). I might have 1.5 inches of clearance and the axle rarely hits the frame.
