Timing Marker _ Crate Motor
Quick Question...
I've got a new crate motor that I'm adding some pieces two; last night I installed a one piece oil pan gasket and a new timing cover. With the cover off I saw that the timing wasnt aligned TDC. Should I have any concerns when installing the new balancer and more specifically, the timing mark? Thanks again, R
USCG "Support Search & Rescue, Get Lost" |
Re: Timing Marker _ Crate Motor
Your scaring me.......I have a crate installed in current project but haven't fired it yet
Well lets both cross our fingers and see what kinda response I get
Do you mean it wasn’t aligned dot to dot?
Did you turn the crank to line them up? |
Post Whore
![]() Join Date: Feb 2016
A photo of what you found would be helpful.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Correct, the two sprockets both had dots, they were not aligned. I would take a pic, but I've got the pan and cover back on; but the nuts are not torqued down yet. I'm trying to avoid taking it all off again.
When I initially saw that they were not lined up, it crossed my mind to turn the motor over to fix it. The problem was that I just dont have the tools to do so; there's nothing to torque on in order to move the crank.
![]() Join Date: Oct 2009
Gotta describe in more detail. If the dots aren't lined up (if that's what you're referring to), that most likely just means it's been rotated (hopefully AFTER the dots were aligned when the chain was installed). And the builder would definitely need to rotate after chain installation. I don't know if, for instance, GM rotates all to TDC on #1 before they ship, but I kinda doubt it as there is no reason to. If your distributor isn't installed yet, you will need to figure things out before you install. If it was installed by the builder, then I probably wouldn't worry too much (but I would be checking it all out anyway - TRUSTNO1.... (cue X-Files music))
EDIT: Ah, sorry, you posted #6 while I was typing with my thumbs. Was the distributor already installed by the builder? Recommend invest in a crank socket and breaker bar (though a 1/2 drive ratchet should turn it over pretty easily) or, if your balancer is installed, one of those Gucci flywheel/flexplate clamp wrenches to be able to turn the motor over. Remember, easier with the spark plugs out). Regardless of how much I trusted the builder, I'd want to confirm proper timing before firing. But to your original question, it doesn't mean it's NOT timed just because the dots weren't aligned when you pulled the timing cover. Last edited by jocko; 02-13-2018 at 12:28 AM. |
No the distributor is not installed.
From what your saying, and probably the direction I'm heading, the safe bet is to get a crank socket and line it up. After that is done, is it as simple as installing the balancer and then the timing marker?
![]() Join Date: Jan 2001
Just remember- dot to dot on a SBC is #6 firing. The timing mark will align, but you'll need one full rotation of the crank to get to #1 TDC for the firing stroke, which is where you want to be when you install the distributor.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#10 | |
BREAK BREAK You can button things up at that point. When it comes time to install the distributor, recommend do a search on here for how to do it properly. Keep in mind that when the timing dots are aligned at 6 and 12 o'clock on the cam and crank gears, respectively, that the engine is actually at the EXH stroke on #1 cylinder and the firing stroke of #6 cylinder. So, ya gotta keep all that in mind as you install the distrib. It's best to think of the timing dots as simply the aid that helps you get the crank and cam properly timed - ignition timing is a separate animal. EDIT: DANG I type slow... truckster hit the nail on the head with what I was trying to get across in the last paragraph. And to install the distrib, I do just what he said: if you lined up the dots at 6/12 and button up the engine - then rotate the crank around 1x back to the same TDC point (or initial timing advance point) and THEN drop the distrib in with the rotor pointing toward #1 cyl - and confirm it is lined up with the #1 plug wire tower on the distrib cap when you install it. That will get you close enough to start the motor - then you can adjust/refine initial advance with a timing light after you start up. |
perfect response; thanks for the quick turnaround.
Is your timing marker a bolt on or is it already attached to your timingcover?
#13 |
its a bolt on
#14 |
Bolt on might be more fun! Or a pain!
Is it an adjustable bolt on that lets you move the zero mark to fit your balancer? And how accurate do you want to be? |
#15 | |||
"I ain't nobody, dork."
But dot to dot will be #6 TDC. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
