Slow Crank when Hot
All, my C20 cranks slowly when the engine is hot. I have a new battery and when I charge it cranks rapidly. But after several drives I get a slow crank.
Any ideas on where to check first? thanks |
Re: Slow Crank when Hot
weak starter , but check all connections first
Stan 67 swb BLU MULE posted via flip-fone |
What he said and add a heat shied to your starter. You can also duct some fresh air to starter.
Overheated starters seem to crank less than desired when compared to cold starts, and bad wire connections when overheated will transfer less electrical power.
Slightly off ignition timing can also effect the crank rate of a motor that is up to temp. Don't ask me to explain that one, but I have found that a cold motor that starts fine with the timing a little off will have a harder time starting once it's warmed up. Make sure all your wiring connections to the starter and battery are clean and shiny as mentioned, then look into shielding the heat from the system, and/or have your starter checked out. You should check your timing too, maybe retard it a bit when up to temp and try the starter right away.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Post Whore
![]() Join Date: Feb 2016
Starter solenoids are part of the draw on the battery when starting. When they get old and the wiring inside starts to break down they draw more current due to increased resistance, this in turn leads to a slower turning starter. Heat causes the resistance to increase and the problem is more pronounced. The same problem can occur with the windings inside the starter.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Jan 2016
How is the alternator output? 14.2 volts or so. If you know the starter is ok...maybe the charging system is not keeping the battery up. Easy to check...just my 2 cents. Loose connections a possibility. Good luck
The new starter will help for a while, but the core problem will return. Heat soak on the starter motor. I was having the same issue with numerous starters, but then I put one of those Kevlar heat blanket on, and fabbed a heat shield that I attached to the header. Haven't had an issue since.
thanks for the info guys. will clean connections then look to a starter.
![]() Join Date: Feb 2012
Those mini starters with a heat blanket works good.
This has happened with my 71 before and it turned out to be the starter. I replaced mine with a Vette starter of the same period and now it cranks like a beast. It could also be too much timing advance.
laying low
![]() Join Date: Mar 2001
There are plenty of threads about hot start issues over the years. Heat soak is the usual culprit. There are also plenty of ideas of how to fix it.
Start with the basics. fresh battery clean cables charging up to parr engine in good tune
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#13 |
Take a set of battery cables and do this:
Hook one end to the engine block, the other end to the frame. For the other cable, connect one end to the body and the other to the frame or engine block. If this helps, you have a ground problem where the existing ground isn't enough. Should be: Cable between battery and engine (alternator bracket, water pump bolt, or bolt on front of block by fuel pump) Cable between battery and vehicle body (inner fender usually) Cable between engine and vehicle body (firewall and valve cover bolt usually) Cable between engine and chassis (valve cover bolt and frame) Cable between chassis and vehicle body (under cab)
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#14 |
![]() Join Date: Jul 2015
How is your timing? Just a thought.
#15 |
#16 | |
Thanks. I definitely do not have all of those ground points. |
#17 |
how old is your starter? what kind is it- original AC delco starter, or a cheap parts store rebuild?
We have a 79 C30. used to have a 350 in it and no matter what we could only get a few years out of a rebuild starter. We tried everything- checking grounds, new battery, even put the relay kit in to get the starter max juice. none of it helped. Finally we put a NEW starter on, not rebuilt, and never had an issue with it until we pulled the motor. Think it was just cheaper quality parts in the rebuilt starters |
#18 | |
#19 |
Had the same problem on my 67 with a 327. Ultimately found the battery cable to have a pretty good voltage drop. Replaced cable, cleaned all connections and symptoms have not returned. My 2 cents worth.
And FYI, I have what appears to be an original starter.
Regards Steve |
#20 |
BlahBlahBlah
Ive forgotten what year but Chevy put a high torque mini starter on the trucks, sorry its been awhile since I dealt with this issue. I had long tube headers and they were very close to my stock fatty starter. Made a big difference when I switched.
Of course check all the other things mentioned here.
#21 |
I have the same problem... even if its been a few hours, the second start of the day is way worse than the first. I will try the heat shield and check grounds also.
I love this community so helpful... thanks everyone
1977 SWB (c20 conversion) SBC350 Springfield Oregon Instagram: @nevernotchevy |
#22 |
Are the cables the right gauge? Heavier cables are better than lighter ones. A 2 gauge will carry 10 times as much current as a 4 gauge. If a lighter cable was used, It will have too much resistance when hot and won't crank properly. Same goes for all the connections.
#23 |
Moderator
![]() Join Date: Jun 2017
Good old heat soak...
1/ Wrap the headers in heat wrap tape at least a foot in front of the starter and six inches behind the starter. Make it a double wrap thickness and secure it with hose clamps or wire. 2/ Replace the primary starter cable with a #2 cable, making sure it has totally clean connection ends. 3/ Replace the ground cable between engine block and battery ground, again, make sure contact surfaces are really clean. 4/ Check and clean all other ground cables making sure all connections are really clean. 5/ Double check battery charge rate is at least 14.2 volts at the battery itself with the engine running around 1500 rpm. 6/ Check static timing and set at 8 degrees at idle,,,idle being 650 to 700 rpm. 7/ If above fails, replace starter with small format reduction gear style starter that also has a heat shield built into its design. Above all...have FUN !!!! ![]() ![]() ![]() ![]() ![]() ![]() |
#24 |
So I climbed underneath to look at the starter and found that the yellow cable coming from the starter led to nowhere. Any ideas what it is for and where to plug it? Thanks!
#25 |
I figured it out. I have an HEI and i'm reading that yellow wire isn't needed anymore.
