Old 02-13-2018, 05:23 PM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
97 Tahoe dash brake light
Over the last few months, my brake light on the dash comes on when braking. You can feel it in the pedal when it comes on and goes off on the next pump of the brakes.
The brake fluid is fine, no leaks and the brakes work as well as usual.
If its quiet in the truck you can hear a click kinda sound when the light goes off. So it sounds like its right at the pedal inside.
Any ideas?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-14-2018, 12:32 PM   #2
ChevyTech
Re: 97 Tahoe dash brake light
It has memory.
Read the trouble code.
Old 02-14-2018, 02:42 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
Is it the yellow light or the red light?
If it's the yellow light, scan for abs codes.
If it's the red light, you have a hydraulic problem.
95 S_Trucker is offline   Reply With Quote
Old 02-14-2018, 04:20 PM   #4
61_FL_Apache
Who Me?
My scanner will not pull ABS codes, but I can try it..
Its the red brake light on the dash. Same if you had the E brake on.
Steve
2001 Blazer 4D 2WD
Old 02-14-2018, 05:03 PM   #5
61_FL_Apache
Who Me?
Here is a video I made on the way home.
https://youtu.be/SI7bX6mr_0k
Steve
2001 Blazer 4D 2WD
Old 02-25-2018, 12:09 PM   #6
61_FL_Apache
Who Me?
Anymore tips on this issue?
Steve
2001 Blazer 4D 2WD
Old 02-25-2018, 02:09 PM   #7
speedygonzales
speedygonzales's Avatar
Could be several things
My suggestion is to isolate the brake pressure warning switch and go from there.
On the bottom of the EBCM (says Kelsey Hayes on it) facing the master cylinder is a connector. It's below the top row of 3 brake lines and between the 2 lower lines. Disconnect that and do the same things you been doing to get the light to come on.
See if the light won't come on.
Let us know what happens
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 02-25-2018, 03:08 PM   #8
Mr_Rich
Mr_Rich's Avatar
Since you hear it inside the cab I'm wondering if it could be physical problem with the switch hanging off the brake pedal pivot itself.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 02-25-2018, 04:02 PM   #9
61_FL_Apache
Who Me?
Speedy: I unplugged that connector and took another test ride. I could still feel this issue in the pedal, but the light did not come on.
Mr Rich: I tried to look above the column where the switch probably is. Its hard to reach and see. There is a brace/bracket on either side if the column that makes it hard to get to.
The sound it make sounds like a spring twanging but not very loud and you can feel in in the pedal at the same time.
Steve
2001 Blazer 4D 2WD
Old 02-26-2018, 11:27 AM   #10
speedygonzales
A spring sound "toing" is the anti-lock brakes activating
The spring sound you hear is the antilock brakes activating. That accounts for why you feel it in the pedal. We could assume the antilock activation is lowering pressure causing the light to come on. However, I don't think normal operation of the antilock system would light the brake light so my thinking here is the antilock is occurring but it doesn't know it's occurring so it then lights the low pressure signal.
At this point you should have someone with a scanner that can read ABS codes check it out. If need be they can ride along to see real time data.
Again I'm thinking there will be no DTC's and you have a Brake Pressure Modulator Valve problem. But stranger things have happened and checking codes is the correct next step.
Good luck.
Pride and joy
Old 03-04-2018, 10:49 AM   #11
61_FL_Apache
Who Me?
I have not had a chance to get scanned for ABS codes yet, but I did take a video of the noise I hear when I press the peddle when the light goes off.
https://youtu.be/ELdabySrwAE Turn up your speakers. This is more for audio then video.
Steve
2001 Blazer 4D 2WD
Old 05-01-2018, 01:15 PM   #12
speedygonzales
Been 2 months. Any update?
Pride and joy
Old 05-01-2018, 07:28 PM   #13
61_FL_Apache
Who Me?
Thanks for checking in.. I have not had my truck scanned yet. I have some control arm bushings coming this week. So that's on the front burner.
Steve
2001 Blazer 4D 2WD
Old 06-15-2018, 09:06 AM   #14
speedygonzales
Ummm
http://67-72chevytrucks.com/vboard/s...d.php?t=763790
Pride and joy
Old 06-16-2018, 03:08 PM   #15
61_FL_Apache
Who Me?
Nothing yet. I will reply with a solution.
Steve
2001 Blazer 4D 2WD
Old 10-24-2018, 07:26 PM   #16
61_FL_Apache
Who Me?
I know its been a while, but I figured it out.
The rear brake self-adjusters were frozen. This caused me to have to step on the brake pedal twice to get good brakes.
I ended up replacing the master cylinder thinking that was the issue about a month ago. I knew I had to pump the brakes to get good brakes, but I knew I was not loosing fluid. After replacing the mater and bleeding all 4 corners, the issue remained. As you can imagine, I was kinda pissed. So more time went by and then it dawned on me about the rears not self adjusting. I cracked them open last weekend and found that to be issue. I removed both self adjuster, cleaned them very well and put them back. Got the brakes adjusted and had instant great brake pedal!
I apologize for the delays and getting back to you guys, but there it is. Problem solved and cost me $0.
Steve
2001 Blazer 4D 2WD
