02-14-2018, 05:18 PM | #1 |
Pictures of my rear end
Okay, I'm not going Harvey Weinstein on you, I just need help identifying this pinion yoke so I can get u-joints and make a driveshaft. It's a GM 12-bolt but the pinion yoke seems non-standard. Those cups are 1-1/16" but that's supposed to be an outside clip u-joint but there are no retaining tabs. My local driveline guy suspects someone ground off the retaining tabs. I'm much more familiar with Ford rear ends; any classic Chevy guys help me out?
02-14-2018, 05:38 PM | #2 |
Post Whore
Re: Pictures of my rear end
whewww ....that's a relief....I didn't know where you were going with this...haha
02-14-2018, 05:53 PM | #3 | |
. Last edited by MiraclePieCo; 02-14-2018 at 06:08 PM. |
02-14-2018, 06:14 PM | #4 |
This rear end does NOT look like the original one in my '55 sedan.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
02-14-2018, 06:48 PM | #5 |
Here's a better pic with dirt cleaned off. It appears to have the tabs ground away.
02-14-2018, 06:48 PM | #6 |
Post Whore
yeah.....I guess I did didn't I.....haha
02-14-2018, 09:25 PM | #7 |
Tabs are ground off. Get another yoke.
02-15-2018, 04:28 AM | #8 |
02-15-2018, 05:31 AM | #9 |
Because they dropped a ____ needle bearing (or two) into the bottom of the cup, then thought the joint was too long for the ____ pocket.
02-15-2018, 07:09 AM | #10 |
02-15-2018, 01:19 PM | #11 |
Yeah, well, I screwed up a lot of stuff in my younger days. I never ground out the tabs though. I just fixed the bearings.
02-15-2018, 04:01 PM | #12 |
Would an inner c-clip style u joint help him?
02-15-2018, 04:24 PM | #13 | ||
02-15-2018, 05:00 PM | #14 |
Here's a list of U-joints from Randy's Looks like there is a bunch of different styles and spreads. Assuming that it's a 1310, 1330 would be different yet.
https://www.ringpinion.com/b2c/Parts...ID=5&CatID=104 |
02-15-2018, 10:57 PM | #15 |
When you save and expend the last photo that is super clear you can see what's left of the tab on the right hand side where I circled it. If you were desperate you could build it up with weld and then take a Dremel tool or die grinder to it but that is a bit chancy. The price of a new yoke is probably inexpensive insurance against problems or vibrations.
02-15-2018, 11:22 PM | #16 |
Yeah, I already ordered a new yoke. Shame the PO had to ruin a $100 yoke instead of buying a $15 u-joint. Evidently he just centered the u-joint by eye, then clamped it down. Doesn't sound safe to me.
02-16-2018, 11:12 AM | #17 |
Here's a Craigslist listing of a rear end that looks a little like yours. Even has the square bosses near the axle tubes.
https://cincinnati.craigslist.org/pt...474420966.html Hope this helps in identifying your yoke.
02-16-2018, 04:11 PM | #18 | |
The way my luck runs if I had tried to run it that way the U joint cup would have slipped sideways and I'd have the driveshaft shaking and baking as I went down the road.
