Before and After
72 250ci Fuel Pump Block off Plate
I though this would be an easy project of swapping to electric fuel pump when I moved my fuel tank to the rear of the truck. the only issue i have at this point is finding a block off plate that isn't $40+.
2 Questions... 1.) would it harm anything if I left the mechanical fuel pump in place if I am using an electric unit? 2.)Does a SBC block off plate fit the I6? I haven't been able to see if they interchange, but they look very similar.
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
Re: 72 250ci Fuel Pump Block off Plate
Summit has for $3.97.....
Stan 67 swb BLU MULE posted via flip-fone |
I took a fuel pump gasket, traced it out on a piece of aluminum, cut it out, drilled holes to match gasket and had a block off plate for the price of scrap. Steel or iron could be used also.
![]() Join Date: Feb 2002
Mechanically nothing. I have kept a mech fuel pump on the 454 when I ran an electric pump to the rear tank on my '67 K/10 Suburban. [Actually it was the PO's set-up.] Came in handy one dark night when the electric pump died. I was able to connect the fuel lines back onto the mech pump and get home. Later, I replaced the PO's cheap pump with a Holley Red pump. I used a block off plate. Ran good for years.
Of course, if you're ditching the mech pump for performance gains of that much less friction on your cam, then keeping the mech pump on, negates the hi-performance value of the electric pump. Block-off plates can't be that much. Are you shopping in Beverly Hills? The L6 fuel pump gasket does look an awful lot like the BBC's. SBCs are different and have 4 bolt holes. It's nasty and raining tonight, so I'll have to compare later.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-14-2018 at 10:35 PM. |
I asked about a BBC block-off plate on an L6 250/292 on www.inliners.org.
Tom Lowe of 12Bolt.com said he had ''used SBC plates with success. They barely cover, but do get it done''. Personally, I like lowbucktruck's lo-$ approach. Get a gasket, and trace out a shape on some aircraft skin, cut it out and drill the holes. There you go.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-15-2018 at 03:31 AM. |
#6 | |
#7 | |
The BBC block-off plate is a lot cheaper than $40 CAN in either Jeg's or Summit, or possibly your local hot rod shop or O'Reilly's if they have a ''candy store'' [hi performance parts section.]
No, I just took the fuel pump gasket and traced it out and used the two bolts. I also did the EGR on my vette's aluminum intake the same way. I didn't replace the bottom plate I don't think ( I did this 25 years ago and I have a bad case of CRS)
#9 | |
Then I mentioned your trick, unrelatedly. Sorry.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-16-2018 at 12:22 AM. |
Before and After
Im sure the BBC would work if modded. I am by no means removing the mechanical pump for HP gains, I am not 100% sure it will suck the fuel from the rear of the truck when it has sat for a while (weeks or months at times). Would the Electric be a better option than mechanical for this aspect?
Before and After
#13 |
I hear www.mrhotrod6.com has a CNC block-off plate specifically for inlines. More symmetrical, but more expensive. About $25 before S&H.
