Moderator
![]() ![]() Join Date: Aug 2011
Another Fastener Supplier
Just FYI, look what I found:
studs Hex - http://www.amkproducts.com/bulk2.asp...%2D+Hex+Collar Hex flange - http://www.amkproducts.com/bulk2.asp...%2D+Hex+Flange And stuff: http://www.amkproducts.com/bulk1.asp ![]()
Re: Another Fastener Supplier
AMK has always had the best nut and bolts for restorations
the bolt depot has some neat stuff also.
1961 chevy K10 my build is------------61K10 build |
Moderator
I use them also but the studs like that I have never found them previously.
Never Ending Projects
That is awesome!!!! Nice share.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() ![]() Join Date: Apr 2012
If you have the GM part number , they have your bolts !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
